Behringer DCX2496 digital X-over
Old 31st March 2013, 09:34 PM   #3471
Davey is offline Davey  United States
Sin Bin
Originally Posted by AndrewT View Post
I suspect overheating during soldering.
I do too. Those polystyrene capacitors are very fragile (soldering-wise) relative to other types.
Dave.
Old 1st April 2013, 10:23 AM   #3472
AndrewT is online now AndrewT  Scotland
Originally Posted by peterhenk View Post
................................., I have put a 332 ohm resistor on the digital in transformer and took out the 110 ohm one (I have installed toslink, and run Spdif directly to the PCB).
Now the digital in fluctuates between as should and highs muted?? Never had this before. .................
Is the line 75ohm or 110ohm?
You must terminate the line with the correct impedance.
Is the line at the send end also correctly terminated?
regards Andrew T.
Old 13th April 2013, 10:06 AM   #3473
wxn is offline wxn  Lithuania
wxn's Avatar
Yet another DCX2496 mod...
List of changes:
1. Changed all big caps in the PSU to Panasonic FC
2. Added small local caps for DACs and opamps in the analog-out board
3. Replaced 4396 DACs to 4396
4. Replaced all analog-out opamps to NE5532 (I just like them)
5. Bypassed the signal electrolytic in the unbalanced portion of the output. Output DC was not hurt.
6. Changed some gain-setting resistors around first two opamps in the analog section to lower gain to about 1. Net effect is that full scale output should be ~2Vrms on each leg of the XLR. Much more manageable in home environment.
Changes are color coded in pink in the pictures. I'd like to hear comments
Nothing is as simple as it seems
Old 13th April 2013, 04:06 PM   #3474
enjoybiking is offline enjoybiking  United States
Lower noise regulators? Better clock{s}
Old 18th April 2013, 04:16 PM   #3475
dmccoach is offline dmccoach
Thank you in advance... I have a unit that has suddenly started to
malfunction... Here is what I have been through:
1. Channel 4 started to intermittently trip my amps protection circuit
2. I opened the unit up and while operating it (music playing) I wiggled the
ribbon cable to the output board (the large one) and heard what I've read on a
few forums as described "popcorn" or bacon "cooking"
3. I removed the ribbon cable from the harness on the output board and with a
scissors carefully cut off maybe 2mm of ribbon removing the original holes made
by the harness creating a "fresh area"
4. I used the plastic harness cover to press the new ribbon end (the fresh area)
onto the harness driving the sharp connectors up through the ribbon wires so it
is seated just like it came from the factory
5. I plugged all back in - All channels work fine - except - Channel 4 continues
to trip the protection circuit on the amp -- but -- when I wiggle the newly
seated ribbon the "pop corn" sound is GONE - so at least I cured that.
Question: I have decent soldering skills and I do own a decent meter, but how
MIGHT I go about debugging what might be wrong with Channel 4?
Thoughts? Suggestions? Thank you
Old 18th April 2013, 09:26 PM   #3476
Pano is offline Pano  United States
Pano's Avatar
Yes, good idea. I used Panasonic FM, but either series are better than what's originally in there.
Also a good idea. I've found that this makes a big difference to perceived dynamics. I don't know why you left the leads long, I just pulled the original caps and replaced them with double the value Panasonic FM. Keep the leads short.
That sounds like a difficult change over.
Good idea. Even better is to do away with the opamps altogether and use a passive output. I like transformers, other people like caps. You might try lat later, to hear if you like it better.
Cleaning up the power and getting rid of the bad output stage will really transform the sound of the unit. Good work!
Take the Speaker Voltage Test!
Old 18th May 2013, 05:27 PM   #3477
hirohiro is offline hirohiro  Japan
Hello, this is my first post to diyAudio.
Inspired by the linuxworks mod in last December, I put a WM8805 digital output board in my DCX2496.
Actually I bought a WM8805 DAI board from the following, and configured with the pins.
????BlogAI?????????????WM8805_G??????
(sorry they only have Japanese page.)
A level shifter, 3.3V AVR and a transformer were put on the small additional board glued with the board.
http://www001.upp.so-net.ne.jp/home-...dcx2496/01.JPG
http://www001.upp.so-net.ne.jp/home-...dcx2496/02.JPG
Since R3 (100ohm to DAC SDATA) decreased signal amplitude and WM8805 didn't work, I removed it. The above picture was taken before the removal.
Sound quality improved very much!
Next mod is to put a SRC&Clock from Pilgham Audio. I'm looking forward to playing with it.
Old 10th June 2013, 09:56 AM   #3478
sek is offline sek  Germany
sek's Avatar
Hey Owen,
would you like to elaborate on your announced 'Behringer DCX2496 Upgrade Board'? Here might be the right place to discuss the DCX related aspects of it, but I'm sure you'll also want to open a dedicated thread for the actual project itself.
I too am getting very frustrated about the DCX lately. I'm too cheap and time constrained to try other DSP platforms, but living with an (almost) stock DCX2496 really is a pain.
Thanks,
Sebastian.
Old 11th June 2013, 02:53 PM   #3479
falvespinto is offline falvespinto  Portugal
Default Help on Linear AUDIO mOD
HELLO ,
I BOUGHT ONE OF THIS KITS ( LINEAR AUDIO ACTIVE, V3) A WHILE AGO AND STARTED IT BUT HAD LO LET IT ASIDE FOR LONG TIME. i RESTARTED COMPLETING IT NOW, BUT SOMEHOW LOST THE LIST OF THE COMPONENTS, SO NOW i DONīT HAVE AN IDEA OF WHAT VALUE IS R23 OR C11 OR WHAT IS U7 ON THE BOARD....
DOES ANYONE HAVE THE BILL OF MATERIALS WITH THE DESCRIPTION OF THE COMPONENTS AVAILABLE?
THANK YOU FOR YOUR HELP.,
FERNANDO
Old 15th June 2013, 07:00 PM   #3480
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Default might start from output of chanel 4
Just a idea that channel 4 is sensing something there ,like a overload,I would disconnect that output and see if it's still acting up,if so,start from the out put backwards ,you got 5 other circuit's working,so compare what is there to each point,something will be different,look for heat problems and use your finger,and nose to see any thing has got hot,
The schematic is on yahoo groups(DCX2496) in the file section,I'm kinda leaning to a opamp going bad ,but find the fault ,I use a infrared temp meter ,it tells on components getting to hot,lol.
Also do a reset on the settings,just in case channel 4 was not set right, good luck,Post your results,and ask as you go ,lots of people to help you here!
NS
Behringer DCX2496 digital X-overHide this!Advertise here!
Copyright ©1999-2017 diyAudio
