Behringer DCX2496 digital X-over
Old 8th March 2012, 04:23 AM   #3221
Pano is online now Pano  United States
Pano's Avatar
Originally Posted by Draki View Post
Anybody else to chip in?
I put about 3.3K after the transformer so that there is a combined load of around 1.5K seen on the primary. It doesn't seem too critical. A Zobel could also work, but I find the 3.3K flattens the impedance just fine.
Originally Posted by AndrewT View Post
Any DC imbalance in the primary circuit will lead to increased distortion as a result of increased saturation of the transformer.
How much DC imbalance do you think there is? How much current will flow thru the primary?
Take the Speaker Voltage Test!
Old 8th March 2012, 09:17 AM   #3222
I don't know the DC imbalance, nor how it might vary with operating conditions.
I don't know the DC resistance of the audio transformer's primary.
Pano,
Do you really expect me to answer your two questions?
Can I assume you are not demanding an answer?
regards Andrew T.
Old 8th March 2012, 09:44 AM   #3223
Viper_user is offline Viper_user  Europe
Viper_user's Avatar
Ok thank's. It works!
Old 8th March 2012, 06:33 PM   #3224
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
Easy enough to measure; put a DCmV meter across the transformer primary. There isn't any. You can connect a transformer directly across the output pins and you're fine.
Old 9th March 2012, 07:49 AM   #3225
Draki is offline Draki  Macedonia
Thanks for making the effort.
Old 10th March 2012, 11:02 PM   #3226
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
If I have done a modd ala`Jan Didden (with caps) is it still possible to take an unballanced signal by connecting pin 1 and 3?Or will it hurt the DAC?
Regards Åke
Old 10th March 2012, 11:26 PM   #3227
Pano's Avatar
Uh... yeah. I was hoping you might know something that I don't. From your answer it just looks like wild speculation on your part. If I get a chance, I'll measure it.
Thanks anyway.
Old 11th March 2012, 11:33 AM   #3228
Not wild speculation.
All audio transformer manufacturers, that I am aware of, warn of the risks of allowing DC into the transformer.
regards Andrew T.
Old 11th March 2012, 12:37 PM   #3229
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Thanks anyway.
Pano, DON'T measure the resistance of a transformer with a multimeter. Indeed, sending DC through the coil (as the multimeter will) may magnetize it and that will increase distortion and decrease induction.
It depends on the type of transformer whether the effect is significant or not, but it's worst for low signal low level transformers like input transformers.
SE output transformers necessarily have DC going through them and they have an air gap to avoid the effects of DC.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 11th March 2012, 12:39 PM   #3230
jan.didden's Avatar
Are you only taking one phase from the DAC to say pin 2, and leave the other phase alone?
That should be no problem.
jan
Behringer DCX2496 digital X-overHide this!Advertise here!
Copyright ©1999-2017 diyAudio
