Behringer DCX2496 digital X-over
Old 7th January 2010, 09:29 PM   #2201
Pano is offline Pano  United States
Pano's Avatar
OK, I've been trying to figure out how best to measure this thing. But I've run up against hardware limitations.
I started a new thread here - http://www.diyaudio.com/forums/equip...conundrum.html - to ask for advice.
Any help is welcome.
Take the Speaker Voltage Test!
Old 7th January 2010, 09:54 PM   #2202
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
Originally Posted by doug20 View Post
I spent a long time reading the threads on the DCX and I guess I have missed the posts with valid measurements showing the differences.
Ahha...
– at on hand it does not make sense to invest into measurement too much as correlation between low distortion and good sound is quasi non-existent (the examples I gave in my last posting should be real world prove enough) - or lets put it to be "a heavily mixed bag" - to say the least
– on the other hand – again - tell me how *you* set up meaningful (valid as you call it) measurements for the topics I mentioned here:
about matching outputs
http://www.diyaudio.com/forums/multi...tml#post597703
about decoupling caps in analog section
http://www.diyaudio.com/forums/multi...tml#post601780
and last but not least I don't agree as there actually were measurements done to backup findings that at least to me were valid (meaningfull)...
about analog input sounding "better" than digital one
http://www.diyaudio.com/forums/multi...ml#post1076324
http://www.diyaudio.com/forums/multi...ml#post1078300
(plus measurements ! )
Last linked posting clearly shows that you simply can not decide by *measurement* what actually *is* better sound wise...
But you and anybody is welcomed to prove me wrong - by *valid measurements*
Michael
Old 7th January 2010, 10:45 PM   #2203
mige0's Avatar
What are you actually trying to measure or prove by measurement?
I mean
- if you plan to change opamps its easiest to look up their specs (which are absolutely meaningless in my experience)
- if you plan to change DAC filter section you will not have enough hardware with a simple sound card (of whatever precision)
- if you plan to measure jitter - well - I really wish you good luck in interpretation
- if you plan to measure interaction of outputs you may check if your sound card can handle enough inputs simultaneously first
- if you plan to measure transparency you first have to define the spec itself, as lowering distortion is by no means correlated to increasing / preserving transparency
- if you plan to measure the ill outcome of relay on IN-1 (or was it IN-3 ?) you will have to look out for additional acceleration measurement equipment
- if you want to measure what influence it has to uplift the ribbon cables you will probably want to look after pretty sophisticated gear
- and so on and so on
bottom line - don't let you force into this, Pano (though it can be fun to do - as long as you don't await especially meaningful output)
Michael
Old 7th January 2010, 10:48 PM   #2204
Pano's Avatar
Mostly noise and harmonics. That would be the first tests and maybe the only ones I can do with limited hardware.
Old 7th January 2010, 10:57 PM   #2205
DougL is offline DougL  United States
I mean
- if you plan to measure transparency you first have to define the spec itself, as lowering distortion is by no means correlated to increasing transparency
- if you plan to measure the ill outcome of relay on IN-1 you will have to look out for additional acceleration measurement equipment
Michael
I think you have adequately quantified the problem.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 7th January 2010, 11:17 PM   #2206
mige0's Avatar
As said - you are facing hard times to prove any correlation to *sound improvement* on the levels of noise and harmonics given !
Just remember the old IC spec stories and how they were praised back then as to be way beyond any of our hearing ability...
Though - you might get some inspiration here:
Geddes on distortion measurements
Michael
Old 7th January 2010, 11:47 PM   #2207
On Hiatus
SY's Avatar
If it affects the A/D or D/A, the result is easily measurable- plain ol' harmonic distortion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th January 2010, 11:51 PM   #2208
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Yeah, we get it! Great measurements don't equal great sound - that horse is looong dead, stop whipping it!
Everyone of the tweakers trots out those testing results by Geddes to show that THD doesn't make a difference. If they said otherwise you certainly wouldn't see them here.You act as if THD is the only measurement - there are others that are important also.
Old 8th January 2010, 12:07 AM   #2209
Pano's Avatar
That's why I want to try some others, too. I haven't done any Geddes trotting, John. Have I?
Old 8th January 2010, 12:27 AM   #2210
MJL21193's Avatar
You lack the religious zeal of a true, dyed in the wool tweaker.
I bet you feel slightly uncomfortable at the meetings.
Behringer DCX2496 digital X-overHide this!Advertise here!
