Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th January 2010, 12:07 PM   #1
Default 33 ohms series termination
Why do we use 33 ohm termination on digital lines and where should be they placed (near to transmitter or receiver or in the middle, if the line is bidirectional)
Old 21st January 2010, 06:22 PM   #2
Joris is offline Joris  Netherlands
Joris's Avatar
I found something like that in my CD-ROM cd-transport. I just removed it, it improved sound quality. I think it is used to limit the possible current when the ouput of the digital signal is shorted.
Kind regards,
Joris
Old 21st January 2010, 06:44 PM   #3
diyAudio Moderator Emeritus
jean-paul's Avatar
It is to filter RF out of the signals in combination with the input capacitance of the following chip. Also to limit currents.
It's only audio
Old 21st January 2010, 06:55 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Kind regards,
Joris
If it is termination, it is between signal and ground, like a load. It does not limit current (it takes current!). The purpose is to terminate the line to improve the signal shape (square wave). Without it you get a lot of ringing and phase shift.
jd
/Another new issue: Linear Audio Volume 3!
Old 21st January 2010, 07:08 PM   #5
jean-paul's Avatar
It is all in the word "series" janneman.
It's only audio
Old 21st January 2010, 07:23 PM   #6
janneman's Avatar
I didn't see any 'series' word, J-P. Anyway, the OP talked about 'termination' and that is normally from line to ground. You can even have active termination to improve the signal and suppress excessive ringing.
It's often used on high speed digital lines where signal integrity is important.
Edit: http://en.wikipedia.org/wiki/Electrical_termination
Edit 2: for bidirectional lines usually there is termination on both ends.
Edit 3: Ahh yes, the series word is in the thread title. OK.
jd
Old 23rd January 2010, 11:08 AM   #7
aparatusonitus's Avatar
If it's transmitter -> receiver case, resistor is close to transmitter, cap is close to receiver.
For bidirectional line...well I'm not that smart
Non é mai abbastanza...
Old 23rd January 2010, 12:20 PM   #8
janneman's Avatar
No, termination is always at the receiver side. The waveform integrity at the transmitter end is controlled by the transmitter, it's at the receiver where you need to control ringing and reflection.
And what's that cap? There's no cap in a termination.
BTW Do we agree we talk about termination as in signal to ground termination, NOT any series impedance? If it is series impedance, it's not termination in the normal sense, maybe more current limiting.
jd
Old 23rd January 2010, 03:48 PM   #9
janneman's Avatar
jd
Just thought about something. If it is a series resistor at the source (or receiver) and a cap to ground, that would of course slow down the rise- and fall times and decrease ringing. That would be suboptimal imho; the slower rise/fiall times make the switching point less well defined and will increase signal jitter.
jd
Old 23rd January 2010, 03:52 PM   #10
Don't forget to add wire lenght, so you will have RLC LP filter at the end.
Load termination cathode_ray Instruments and Amps 5 23rd August 2007 10:57 PM
Load termination ? cathode_ray Tubes / Valves 4 31st July 2007 12:12 AM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Interconnect termination hbarki Parts 0 10th April 2004 01:51 PM
Cable termination dkxdn Digital Source 32 17th December 2003 05:07 PM
Page generated in 0.12902 seconds (83.73% PHP - 16.27% MySQL) with 10 queries
