Get I2S or EIAJ from a Sony CDR
Old 13th December 2009, 03:45 PM   #1
radu19880625 is offline radu19880625  United Kingdom
Default Get I2S or EIAJ from a Sony CDR
hello!
Is it possible to get a I2S or EIAJ from this cd-r?
SONY crx230ee-- and the internal pic.
Thanks a lot!
Old 13th December 2009, 03:50 PM   #2
rfbrw is offline rfbrw
If it has an analogue output look for the dac, possibly an 8 pin device like a TDA1311 or TDA1387. You'll find what you want there.
Old 13th December 2009, 10:01 PM   #3
Well, i looked but audio analog out comes from the big square chip:
MT1585E
Old 14th December 2009, 01:05 AM   #4
wwenze is offline wwenze  Singapore
AFAIK the I2S standard is not found on CD drives, any audio out analogue or digital (SPDIF) is handled by a general-purpose IC, in this picture the big M chip. Saves costs.
Old 14th December 2009, 09:33 AM   #5
thanks... I found the link between audio out-analog and 2 pins from the big chip.
So I guess it's no chance then!
Old 14th December 2009, 02:56 PM   #6
glt is offline glt  United States
Older CDRs do have a separate DAC and you can tap the "audio interface lines". They are the same as I2S, but could be left justified, or right justified or 16 bits. I have pulled these lines from two different CDRs into an ASRC (so I didn't need the clock). But if you want straight connection to a DAC, you will have to find the clock (MCK) line. Then you will have to program/set the DAC accordingly. So look around for old PCs and pull the CDRs. The older the better.
I've done some measurements on I2S lines in my blog...
www.hifiduino.wordpress.com
Old 2nd January 2010, 08:43 PM   #7
fzaad is offline fzaad  Europe
hi glt what kind of measurements you have done with i2c. I'm just wondering since we are talking digital interface. If aint bit perfect then you fail.
Get I2S or EIAJ from a Sony CDRHide this!Advertise here!
WTB: EIAJ to I2S converter PCB guglielmope Swap Meet 5 13th October 2012 11:36 AM
EIAJ to SPDIF??? stefaca Digital Source 1 4th September 2006 01:37 PM
I2S and EIAJ johnthedoctor Digital Source 0 21st July 2006 06:13 PM
Can you find the EIAJ? (Sony D-2) velmeran42 Digital Source 1 23rd August 2005 04:43 AM
Split L & R DATA of EIAJ(?) DragonMaster Digital Source 0 12th March 2004 12:35 AM
