diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Line Level (http://www.diyaudio.com/forums/digital-line-level/)
-   -   AK4393 burn... (http://www.diyaudio.com/forums/digital-line-level/156689-ak4393-burn.html)
CIMONE 13th December 2009 02:08 PM
AK4393 burn...
Two channel of my digi002 is gone, the AK4393 dac chip is death! my error when trying to upgrade the output opamp, i have a few cs4223 chip here, is it possible to replace AK4393 to cs4223 with little modification? Any help will be appreciated...thank you.
YohY 24th June 2011 09:23 AM
Blown dac chip
Just drop an AK4395 back in, as it's (reportedly) the better chip out of the 4393/95/96 line..!
Radugazon 24th June 2011 01:23 PM
Sorry for your misfortune, but can you explain what kind of mistake you have done please ?
Like this I will not do the same...
MikeHunt79 24th June 2011 01:35 PM
Originally Posted by YohY (http://www.diyaudio.com/forums/showthread.php?p=2617346#post2617346)
I think the AK4395 needs a slightly different supply voltage, but the AK4396 should drop right in. :)
YohY 24th June 2011 02:14 PM
Originally Posted by MikeHunt79 (http://www.diyaudio.com/forums/showthread.php?p=2617560#post2617560)
This is already covered on the forum...just needs a search around the begining of this thread..
http://www.diyaudio.com/forums/digit...93-5532-a.html :D
YohY 24th June 2011 03:12 PM
Here you go :
Originally Posted by sendler (http://www.diyaudio.com/forums/showthread.php?p=2533394#post2533394)
The AK4396 dac chip is a drop in replacement for the 4393 and sounds much better. The AK4395 sounds even better than that but requires a 5v digital supply.
Copyright 1999-2017 diyAudio
