| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#41 |
TDA1549 internal opamp bypassed:
just to make it more clear
Rudolf Broertjes |
#42 |
Got the TDA1543 working. For the I2S I used two direct solderings to pcb's wires (jumpers) and one short (5cm) coaxial wire. Outputs and Vref have 1K metal oxide 0.5W resistors. 47k resistors to ground. And 4.7 uF regular electrolytics. In the psu wires I put a 22 uF and a 1 uF caps.
I just dont know where to get a decent 5V supply indide the player. For now I connected it to the uoput pin of the 7805 chip and the ground is directly to the case. But this is not a good solution... The sound level is a bit low, even with the maximum level on the cdp (yes the volume control still works ). I tried to use my EF86 based pre but it didnt solve it (has not enough gain). As I use a opa549 gainclone, maybe I increase the feedback resistor to get more gain.Miguel |
#43 | |
Banned
Also my experience: output is pretty soft, low with 1k resistors and passive conversion. With 3k65 as Rconv as in Rudolfs schematic and a OPA604 opamp I got a lot more power and output. ![]() ![]() (10 clicks on my volumecontrol or about 15 dB) |
#44 |
I have a couple of OPA134s that I can use there, in a typical configuration used by TI in the dacs sheets.
Miguel |
#45 | |
Banned
OPA134 also works. I tried OPA2134. OPA604 has slightly more refined sound.
#46 |
Hi Elso,
Can you point me a schematic of the Rudolfs dac? Yesterday I tried the OPA134s and could not get it working. The TDA1543 alone works well. And my implementation of the OPA134s seemed to work well too, with inverted input and unity gain (for starting). But when I connect the output cap of the TDA1543 to the input resistors of the opamp the sound becomes very degradated and with a lot of hum. I tested both the outputs of the dac and the opamp. I believe that I grounded well everything, so there must be other problem... Miguel |
#47 | |
Banned
#48 |
Like this? Isnt this active I/V conversion?
Miguel |
#49 | |
Banned
Yes that's active IV-conversion
#50 |
Here is what I used. After the output cap I think I can connect any opamp there, like the opa549 from the gainclone that works well. So the opa134 should not give problems. I tried to use the Vref of the dac in the + pin but had no changes. time to think a bit more...
| Thread Tools | |
| Tubelab Simple SE Sound Quality | TV Man | Tubes / Valves | 3 | 9th July 2009 07:23 PM |
| Good quality 6600 CT OT | Valvomaniac | Tubes / Valves | 4 | 2nd April 2007 09:56 PM |
| Good Quality Sub | krillan092 | Subwoofers | 1 | 19th January 2005 09:25 PM |
| Looking for a good quality DIY design...Please help | philcav7 | Multi-Way | 8 | 19th November 2002 04:51 AM |
| Page generated in 0.10698295 seconds (81.08% PHP - 18.92% MySQL) with 11 queries |
