Try to build an old style DAC, PCM1702
Old 13th November 2009, 05:24 AM   #1
bbp is offline bbp  China
Default Try to build an old style DAC, PCM1702
Just finish the work hours ago
CS8414 as the DIR receiver
DF1704 standard DF
PCM1702U X 2 DAC satge
OPA627AU as the I/V converter
LT1037 mfb LPF
All PCB made by myself , that made my hands look so poor >_<
The sound is pretty goooood
For the test result, I test the low level signal below:
Source : CD PRO (VAU1254/11) transprot , SONY test cd provides 16bit signal
60 dB Gain amplifier for oscilloscope TDS1020B, so, 100mv/DIV means 100uV actually ^_^
The pics bellow shows :
-60dB sinewave and FFT
-80dB sinewave and FFT
-90dB sinewave and FFT
calm down and enjoy your time in experiment
Old 13th November 2009, 05:29 AM   #2
DF1704 standard DF
LT1037 mfb LPF
and the PCB ^_^
Old 13th November 2009, 05:58 AM   #3
tritosine is offline tritosine
Nice project! I agree with the choices you made . Good job.
I dont see a single shortcoming on the digital part, when compared to newer designs. Not a single one. But you have to make the spdif receiver circuit as good as possible. (No toslink!)
I think I send you some datasheets, when I find it, that can clean up the spdif somewhat.
Old 13th November 2009, 07:02 AM   #4
thanks for the documents you provide, tritosine ^_^
this is the female-board under the PCM1702
Old 13th November 2009, 07:32 AM   #5
... and dont forget you can basically "bypass" the df1704 if you "pre-oversample" the data inside a PC to 88.2khz , and burn those tracks to DVD , or use the PC source . Then the sonic signature of DF1704 becomes insignificant.
Old 13th November 2009, 08:01 AM   #6
I got only USB to SPDIF converter based on PCM2707 and a CD transport of CD PRO ^_^
So the sample rate only runs in 16/44.1/48
I made a mistake on #1, the gain of the amplifier is 40dB
Old 13th November 2009, 10:20 AM   #7
pcm2707 is not good at all and might be obsolete soon, better make a good spdif receiver circuit optimised for 44.1 and multiples.
Old 18th November 2009, 12:06 PM   #8
Nazar_lv is offline Nazar_lv  Europe
Nazar_lv's Avatar
Send a message via ICQ to Nazar_lv
DF1704 is not the best DF( OPA627 too far from the best option, distortions greatly increase with frequency
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) S-Audio.Systems
Old 21st November 2009, 07:24 AM   #9
similar to DF1706, DF1704 is almost the best DF for PCM1704
or you may programme a FPGA to a ultra-high performance DF module ^_^
Old 21st November 2009, 08:39 AM   #10
DF1704 is 2*2*2 . Think of initial 2* oversampling as breaking up 2 sample points into 4. So if you precede df1704 with computer 2* oversampling , the DF going to process the already "broke" 4 sampling points, and insert new ones between those. Therefore , it CAN't be any significant anymore, especially with "slow roll off" mode on.
Try to build an old style DAC, PCM1702Hide this!Advertise here!
My first DIY build vacuum tube style Gainclone. pinoy82 Chip Amps 6 29th June 2007 07:43 AM
Pcm1702 Dac parhelia Digital Source 4 18th March 2007 10:09 AM
PCM1702 sensitive to ESD? klitgt Digital Source 11 14th February 2006 05:22 AM
pcm1702, K grade or not? PatPet Digital Source 30 2nd December 2004 01:51 PM
wtd: PCM1702 kiwi_abroad Swap Meet 2 9th June 2003 07:32 AM
