| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
洞洞板的八爪鱼,不错,照片质量太差,看不清楚。
#12 | |
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua |
#13 |
Digital filters IC's with max 50khz input frequency are the worst ...
![]() Only DF1704-06 and SM5847 counts. 5847 is overpriced. If you care about sound quality , you can use the PC processor to perform 2x oversampling with 64bit precision, and user defined filter roll-offs, you can even use the "apodizing" filter, and no , there won't be any preringing added by the DF1704 then. Use this 24/88.2 format , or dither to 16/88.2 , and write to DVD, these can be done in "batch". I sent bbp drawings of secondary PLL, that should clean up spdif jitter to 50ps, thats sufficient for 20bit perfomance. Last edited by tritosine; 22nd November 2009 at 11:42 AM. |
#14 |
bbp, you should use a simple 2 pole passive anti aliasing filter though, no ? Why active?
#15 | |
I think passive LPF is enough for there's a 8X/16X DF in the DAC
calm down and enjoy your time in experiment |
#16 | |
Hi tritosine,
#17 | |
The best sounding (and technically best) DF are SM5845/CXD1244S/CXD1144BP/CXD2567M/PMD100/SM5842, and all this are 48kHz max
| My first DIY build vacuum tube style Gainclone. | pinoy82 | Chip Amps | 6 | 29th June 2007 07:43 AM |
| Pcm1702 Dac | parhelia | Digital Source | 4 | 18th March 2007 10:09 AM |
| PCM1702 sensitive to ESD? | klitgt | Digital Source | 11 | 14th February 2006 05:22 AM |
| pcm1702, K grade or not? | PatPet | Digital Source | 30 | 2nd December 2004 01:51 PM |
| wtd: PCM1702 | kiwi_abroad | Swap Meet | 2 | 9th June 2003 07:32 AM |
| Page generated in 0.07917 seconds (85.15% PHP - 14.85% MySQL) with 11 queries |
