A New Take on the Classic Pass Labs D1 with an ESS Dac - Page 97 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th May 2012, 05:18 AM   #961
Originally Posted by qusp View Post
so putting basically double the below plus MCU, display and control systems into one case I think would make it impossible to have a clean layout. much easier (though still not easy) to do it with 2
I still have no idea on the MCU, display and control systems, may be waiting for the AC2 from TPA. What is your plan?
Old 17th May 2012, 05:33 AM   #962
qusp is offline qusp  Australia
qusp's Avatar
I will use the AKM MCU unit for register setting and volume/input control of the dac (seen on the bottom left of the above pic, with the volume knob on it, its connected to my mac via an RS232->USB adapter and controlled using terminal (snapshot below)), but the display and monitor/control will be based on a network of 1mW xBee wifi modules and a beaglebone.
the ackodac MCU already has RS232 and non volatile memory for saving functions, plus dip switches and rotary controls; which means all functions can be controlled with both tactile controls, or over USB/wifi/ipad but the beaglebone will allow it to be somewhat antonymous without needing to be connected to my Mac the whole time. i'm treating the whole system of dacs and multiple amplifiers as one system under the control of the beaglebone, so that sequenced start up/shutdown, various voltages and temperatures can be monitored and influenced.
we will start by working with off the shelf modules connected in a network, but ideally I would like to spin a PCB
File Type: png Screen Shot 2012-05-10 at 6.16.42 AM.png (107.1 KB, 255 views)
Old 17th May 2012, 05:40 AM   #963
qusp's Avatar
anyway this is for another thread
Old 17th May 2012, 06:06 AM   #964
qusp was about to email you but since it seems almost on topic given where we're at now with enclosures. I've been working my way through the old posts in this thread ... hard yakka I tell ya.
The final layout for component arrangement is essentially this here, right?
Given these power supply requirements for ess dacs you've posted back in Sept last year in the build thread here and I guess that info is interesting to bigpandahk given the shunt reg discussion in Ian's FIFO thread today too.
So my recollection of the last time I saw your acko+NTD1 enclosure is a bit hazy so I've been thinking through how I would go about arranging the two so I could work out just how big an enclosure I really would need.
The below assumes stereo setup, I'm not crazy enough to contemplate multichannel NTD1.
My question is would it be logical/feasible to use the acko where the shunt regs for the more critical supplies AVCC_L/AVCC_R & VDD_L/VDD_R are used but since they are connecting to 'short' edge of the ackodac pcb they hang over the edges of the NTD1 pcb and don't interfere with NTD1 PSU components. If you were to use an external MCLK rather than the onboard clock (say Ian's FIFO clock) then you don't need to connect any supply to VOSC connection right? That would leave only the DVCC_B power supply needing to get around the issues with the NTD1 onboard PSU components. Would one of those nice looking BLUE stick regulators be suitable for that supply? I was also contemplating 4 x salas shunt regs for the supplies to AVCC_L/AVCC_R & VDD_L/VDD_R actually.
I'm just trying to visualise a layout for how the ackodac AKD12 could be mounted and still use the NTD1 PSU.
For a stereo configuration then you won't need a metric acre of room for the ackodac, maybe just half an acre and some space to place FIFO and a USB interface board with supplies for each.
Old 17th May 2012, 06:44 AM   #965
The blue sticks are perfectly fine to run straight to the dac board for top and bottom ring supplies.
Edit: The only advantages of running the blue stick supply thru the usual acko regs in those positions are the CMC and big *** ferrite bead... which is only a requirement if the blue stick is in another case and then 2 feet away with an unshielded umbilical. IMO disclaimers of course.
Old 17th May 2012, 06:49 AM   #966
Sorry for the 62 successive ninja edits there.
Old 17th May 2012, 06:57 AM   #967
Have you seen the ninja edit's that qusp pulls? Sometimes the final output looks nothing like the original input, terrible distortions there!
I was pretty confident the stick regs would be ok there though not entirely familiar with the ESS gear so was worth asking.
Old 17th May 2012, 08:23 AM   #968
qusp's Avatar
yep, you can use the blue stick regs for the less than critical supplies, just doesnt stack as neatly and you have to sequence them all. the acko MCU needs to be powered up first to manage the register sequence. the current requirements posted are based on using an 80MHz clock, you can buy the dac without the clock even fitted, which is what I would recommend you do, there is a u.fl header under the XO position. ideally with the ackodac you should either mount the NTD1 to a suitably thick floor, then the dac + fifo clock module and then the regs and USB module on a platform above, or invert the whole thing, use a heatsink like mine, with the shunt regs on the floor sinking to the floor, then the dac mounted on them, then the NTD1 + heatsink mounted above them, inverted with the heatsink fins pointing up and visually obscuring all your hard work for neat layout. this could be gotten around by having the enclosure designed so you can see in at floor level.
personally i dont really see the point of using shunts for such steady supplies, you can get steady low noise regs in much smaller packages. for very dynamic loads they are great, but none of the pins you mention are that.
which is what i'm doing, maybe i'll go shielded, but I actually dont think your average screened shield does that much good. the choke also means the whole dac can float and I can tell you after feeding jh13 directly from the bal-bal wire, directly connected to the dac; is a pretty surreal experience. no music playing, full volume, not a whimper of noise, complete blackness....
also not having AC wires going anywhere near the dac makes routing signal (of all sorts) a lot less of a pita
Old 17th May 2012, 08:39 AM   #969
The blue sticks are floating supplies.
Anyway, how would having a cmc make a non-floating supply floating?
Old 17th May 2012, 08:43 AM   #970
qusp's Avatar
yes, in the sense that if you use a dedicated secondary for each one they are floating. maybe I misunderstand and have to look it up, but for some reason I thought common mode chokes were like transformers and thats how they act on common mode noise? maybe its just the appearance. actually maybe i'm thinking of inductors.
ninja.... hiiaaaya!!
those who call me expert can now see i'm learning just as you. no background in this stuff, I learn as I go. i'm off to do some reading
Pass Labs S/Ns ? dejanm Pass Labs 8 26th January 2007 08:35 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Copyright 1999-2017 diyAudio
