| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#891 |
Exactly what he said ^
![]() The chassis looks great, and again, kudos on putting in all the extra work to etch your own board! I'm looking forward to hearing your impressions. I recently took a few more measurements of my NTD1 using a separate outboard ADC and patching it digitally into the AP. This allows more accurate measurements as the outboard ADC has much lower distortion than the internal one on the AP. As I always suspected, distortion is significantly lower than originally measured. Remember this post? A New Take on the Classic Pass Labs D1 with an ESS Dac Compare and contrast to the graphs attached below: 1. DPR @ -4dBFS - 2nd and 3rd harmonics are down 131dB and 127dB respectively 2. DPR @ -6dBFS - 2nd and 3rd harmonics are down 131dB and 133dB respectively 3. FFT of the output @ -6dBFS. Scale the whole thing up by 12dB if you want values in dBV. This puts the noise floor at between -138dB and -158dB! 4. THD vs. Freq @ -6dBFS. Values below 10Hz and above 7kHz are not valid due to high and low pass noise filters at 20Hz and 22kHz. Hopefully that's some encouragement to get your project finished! Cheers, Owen |
#892 |
Hi OPC,
Any schedule for the whole thing to be availabvle for order? Thanks |
#893 |
Great distortion figures. But I'm not too nervous about perfect tech specs. My Aleph30 clone made years ago is still one of my preferred amp, and doesn't test so great. I have a CLIO analysis system and I'll certainly have a look at the specs, but I'll be happy if the dac sounds just great
#894 |
is choosing a less facetious title...
well get ready to be happy
#895 |
#896 |
indeed, hard to describe the sound, but the best way i know how, is that it has all the scary deep resolution of a top flight opamp stage, without sounding like its trying too hard.
#897 |
I added a shunt reg between the on-board regulator and buffalo ll.
With distortion levels so low from source to output tweaks are audible ,this one seems to be a positive one to my ears. My NTD1 Bll combo does not suffer from what I call "digitosis"...you know the junk that makes some of Madeleine Peyroux's recordings fatiguing and sends your tweeters into fits on a most digital systems. I think reviewers call it "glare" Well the glare is gone! Analog tone with digital detail. igwt |
#898 |
Hi. I may doing something wrong. The DAC VA/2 = 1.64V, and can be easily measured at the output of the Buffalo DAC output (nothing connected).
Then without connecting the DAC, I adjusted all four D1 FET gates to the same voltage of 1.64V, easily done. I connected the DAC it is was very wrong. The DAC Vd and Va where drag lower than normal, VD was 4.52V instead of the normal 5V, the DAC stop to works, and the DAC outputs where stuck at -0.7V. If I change to D1 FET Gate until the DAC sees 0V at its output, it is working again, at this point the FET Gate voltage is about 3.3V. With the D1 pot I can vary the DAC output voltage (connected to the D1) from -0.7V to +0.7V only, not the expected 1.64V. It is if like the protection zener are conducting at 0.7 and not 3V. Remember, I'm using my own PCB. It can still be wrong. I already found and corrected a few mistakes. Any idea? Anything to test? Thanks... SB |
#899 |
This could be a few things:
1. The gate voltage is not what you should be measuring! You need to adjust the pots to measure 1.65VDC on the SOURCE of the mosfet (where the DAC outputs connect to) relative to GND. 2. The protection zener diodes were incorrect on the PCB. This error has been covered several times throughout the thread, but it's easy to miss. If you want to keep the protection zeners, you need to make a little tee-pee putting two zeneres back to back on the same pad. There are instructions in the thread somewhere with pictures. Fix the above two things, and you should be good to go. Do not attach the DAC to the I/V stage until you've got the proper 1.65VDC at the source of each fet! If you have a high voltage there, you could damage the DAC. Regards, Owen |
#900 |
thats my fault, I mispoke in my instructions as we had been just talking about gates, so i had gated head; but we corrected that straight away in the subsequent posts. maybe i should get the mods to correct my first post?
| Pass Labs S/Ns ? | dejanm | Pass Labs | 8 | 26th January 2007 07:35 AM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 12:39 AM |
