A New Take on the Classic Pass Labs D1 with an ESS Dac - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 9th March 2010, 01:55 AM   #61
opc is offline opc  Canada
opc's Avatar
Hi Guys,
Please use the updated schematic I've attached. I forgot the 221 ohm gate resistors, and they should be added. The rest of the schematic is the same, and it's correct. Sorry for the omission.
Owen
ChuckT: Try 600 ohms and 1300 ohms for about 1 VRMS output. At that resistance you're probably fine to omit the B1 buffer section, but you might want to make sure you're not driving too low an input impedance on the next stage. When those upper two resistors start creeping over 1k, I'd suggest putting the buffer back in.
Old 9th March 2010, 02:56 AM   #62
pidesd is offline pidesd  Canada
pidesd's Avatar
what are the trimpots for and what value should they bet set at?
Old 9th March 2010, 04:45 AM   #63
opc's Avatar
The trimpots are used to adjust the gate voltage, and hence the voltage present at the source of the mosfet (above the 400 ohm resistors).
Before startup, I would disconnect from the DAC, and set both trimpots to minimum (0 ohms). Increase the value of the trimpots to set the voltage at the source of each of the two fets to 1.65VDC referenced to ground. Once this is done, verify that the voltage at the drain is about 9VDC referenced to ground. If all is good, power down, connect to the DAC output, and start back up. You may need to re-adjust to get exactly 1.65V at each source, but it shouldn't have changed much.
The value of the pot will vary from mosfet to mosfet, so there is no set value for it. If you are using matched fets, you'll get about the same value for each one, but there's no way to tell what value will get you what you need for voltage. Once this is adjusted, I would let the unit run for a few days, then re-check and re-adjust, and you'll be good to go.
If this still seems confusing, let me know and I can draw up a diagram.
Owen
Old 9th March 2010, 06:24 AM   #64
Thanks again, Owen.
I assume the 1300 is the drain resistor that will give me 1Vrms.
I am already using the D1 with +/-30V without the buffer, seems to work ok.
Old 9th March 2010, 07:16 AM   #65
how this compare to original D1 i / v
ChuckT are you using your i / v with pcm63
Old 9th March 2010, 01:31 PM   #66
Hi Owen,
I was looking at the circuit and it occurs to me that the time constant for the gate voltage is much longer than the supplies coming up. Therefore, I would suspect that upon power up the voltage at the source of the MOSFETs would start off negative (because the gate starts at ground) and then slowly rise up to the steady state value as the gate capacitor is charged up.
I am using the PCM1794; and I fear that during power on the current output pins of the DAC chip will be "pulled" negative for a short time. The datasheet specifies a maximum of 10mA current on any pin. I plan to run a simulation of this, but I do not have a model for the DAC output.
Preliminary calculations say that if the DAC chip has an internal diode to ground (for ESD protection) the current will exceed MAX ratings. esentially you have a 400 ohm resistor to -18V for some time until the MOSFET turns on and stabilizes.
Just thought I would mention this to you and see if you thought about it any. I don't see an "easy" solution and I will most likely try the circuit anyway. Hopefully the DAC chip can handle this transient without damage; unfortunately, it can last a long time depending on the time constant used to filter the DC bias on the gates.
audio4life
Old 10th March 2010, 09:32 AM   #67
anbello is offline anbello  Italy
anbello's Avatar
Hi Owen,
thanks for posting this interesting i/v schematic,
i would like to know two things:
1) can the i/v circuit on post #61 be used without change both with buffalo24 (es9008) and buffalo32 (es9018)?
2) can i omit the 10uF out capcitors if i use a transformer to have an unbalanced out?
Ciao
Andrea
Old 10th March 2010, 10:55 AM   #68
Nope, I use pcm1702, similar but lower current output.
I haven't try Owen circuit yet, but I have try one diff mosfet (K216) on the D1 and it sound fairly similar to the irf610.
Old 10th March 2010, 01:39 PM   #69
opc's Avatar
Hi Guys,
Lots of questions... I'll try to address each in order:
ChuckT: 1300 ohms would replace the 400 ohms, and 600 ohms would replace the 185 ohms. This should give you about 1VRMS if you use it in the circuit posted. If you use +/-30V supplies then dissipation might be a little on the high side, and I'm not sure how well it will work. If you want something drastically different then I'd suggest trying LTspice to simulate it first. It's free, and I could even send you the schematic files to try.
samoloko: I had a D1 output stage replacing the op-amp stages in my Resolution Audio CD-50 for a long time, and it was driven by 4 PCM63's just like in the original D1. I liked this setup, but I much prefer the new buffalo DAC with this I/V stage. It's too hand to directly compare both since the DAC's are so different. Today's DAC's output WAY more current than the last generation, which makes the circuit I'm using possible.
Jmertz: Very valid concern, and excellent question. I pulled out the scope, and measured the transient at the input during startup. I've attached the screenshot from the scope, which was taken under normal startup with no DAC attached. The input node swings negative to about -2.9V (this is worst case, I tried it about 20 times on different inputs) before it climbs steadily up to 1.65V. I'll have to consult the datasheet for the DAC, but it should be fine. I might try again today with the DAC attached just to see how that looks.
anbello: Yes, this circuit can be used exactly as it is with either of those DACs. As for the transformer, you could probably omit both caps if you take the time to balance to voltage to an equal value at each drain. Once that's done, you can attach the transformer and you should be good to go. Otherwise, you can use just one capacitor on either side, or between the two primaries if your transformer is setup like that. Either way, you don't need two caps.
Owen
Old 10th March 2010, 01:48 PM   #70
Thanks Owen,
If you get around to powering it up with the DAC chip connected please post the scope shot. Thanks!
Unfortunately the data sheet for the PCM1794 is not very detailed. I think the only way I will know is to try it.
I wonder if anyone else has used the D1 I/V with the PCM1794?
audio4life
Pass Labs S/Ns ? dejanm Pass Labs 8 26th January 2007 08:35 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Copyright ©1999-2017 diyAudio
