| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 | ||||
Sometimes a square peg fits a round hole just fine
anyway mate, looking forward to this project even more now, I reckon we've got a serious contender here. cheers Jeremy |
#22 |
one thing; when I made my order from sumR for my iron, I totally didnt see this coming, so I only have 20va primary, with dual 15v secondaries. I might be able to eek that out to 18v DC in the regs, but it would be touch and go. is 15v DC enough to run the rails on the B1?? or is 18V the minimum?? obviously I could put the secondaries in series, but 12v is a lot to burn off in the regs, would need some serious sinks, could burn some off in a prereg I guess, but then I lose 2 secondaries. unfortunately its too late to change my order for the iron, they should be nearly finished by now; last update I got tyhey were up to enamelling.
#23 |
Hi qusp,
I have the exact same problem. The blue potted transformer I'm using now has 15V dual secondaries, and it's too close for comfort. I'm right on the edge of the regulator's dropout voltage. It does work though, but I wouldn't suggest it in the long term. I ran a quick simulation with +/- 15V and it works just fine. You'll have less voltage swing capability, but I don't see why anyone would want 10VRMS out of a DAC anyway. All you need to do is adjust the top resistors to get about 1/2 Vcc (7.5V) at the drain of each mosfet. In my sim, it was 180 ohms in place of the 200. The adjustable gain feature is pretty slick, since all you need to do is increase the 200 and 400 ohm resistors. I personally don't like a lot of gain, since most systems have far too much as it is, and it results in more noise and distortion for no reason. With this circuit, you get to balance gain with the amount of voltage swing you're willing to accept at the output of the DAC. Less gain = less voltage swing at the DAC. I think a nice 2VRMS at FS is a good way to go, but if someone wants more, it's easily done. One of the things I want to try is dropping the rails down as low as possible, and seeing at what point it negatively affects the sound and the performance. If you only want 2VRMS output, then the rails should be able to go much much lower which would result in less dissipation on the parts, and more flexibility in the power supply. I kept them high in order to allow people to get a lot of gain, but maybe I'll make it an option. Anyone out there with an opinion on gain? Anyone who wants more than 2VRMS at 0dBFS? If so, can you tell me why, and how much you would want? Cheers, Owen |
#24 | |||||
Hi Owen
love the texas components R'sQuote:
thanks for the numbers re the gain setting resistors. great dialogue so far. keen as mustard cheers Jeremy Last edited by qusp; 21st November 2009 at 07:44 PM. |
#25 |
I thought the DAC chip like all S-Deltas had 1/2Vcc DC offset and the D1 stage was designed for R2R DAC with 0 offset, I don't see this being dealt with in the circuit, something to check.
Also we really do need to have a nice discrete balanced to unbalanced mixer to reduce common mode noise and let the DAC chip show its full potential. Very nice project btw. |
#26 |
Hi Regal,
I've addressed this a few times, and I think I mentioned it in the first post. The normal D1 uses trimpots to set the gate voltage on the mosfets. This in turn is used to set the voltage at the source to 0. In my circuit, the same thing is done, except the voltage at the source of the mosfets is set to 1.65VDC which is 1/2 VCC, exactly what the DAC wants to see there. The top two resistors feeding the drains of the fets are then adjusted to get about 9V at the drain of the mosfets, which is what the B1 wants to see at it's input. The final current through the mosfets is about 50mA, which is much much higher than the D1. I have the exact values for all the resistors in the working circuit, but I'm out of town for the holidays and I won't get a chance to work on this again until I get back on the 29th. From what I can remember, you need 400R on the sources, 180R on the drains and adjust for 1.65V at the source. You are correct about the balanced to single ended converter. This circuit works with a single ended output, but you lose all the advantages of the balanced DAC and the balanced nature of the D1B1. Performance definitely suffers for it. I personally don't care to have SE outputs since the entire rest of my system is balanced, but I can understand the need for a good SE output. Anyone with any suggestions? This might be a good spot for a single UG op-amp with good CMRR. A transformer would also work very well here. Happy Holidays! Owen |
#27 |
Banned
Any further collaboration with Acko's DAC?
A suggested op-amp might be OPA365 50MHz, Low-Distortion, High CMRR, RRI/O, Single-Supply, UG op-amp? |
#28 |
#29 | |
Thanks, I just don't see how you can come up with the 1.65V at the Mofset Source from the datasheet, running 50 mA and all the charts are in amps. I guess you need Spice or something. It would be very useful for a lot of us with 5V DAC's to know how to change R1&R3 to get 2.5V at the source. |
#30 |
I guess what I'm asking is how do you change the 1.65Volts at the mofset source to 2.5V which is very common for the Burr Brown DAC's (179x) whould be useful for people building the EZDAC etc.
| Pass Labs S/Ns ? | dejanm | Pass Labs | 8 | 26th January 2007 08:35 AM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 01:39 AM |
| Page generated in 0.10461 seconds (70.58% PHP - 29.42% MySQL) with 11 queries |
