A New Take on the Classic Pass Labs D1 with an ESS Dac
Old 29th November 2012, 03:06 AM   #1451
crazikid is offline crazikid  Australia
buzzforb - 1
Magsy - 1
vitalica - 2
Reenberg - 1
Emphrygian - 1
qusp - 1
Iancanada - 1
crazikid - 1
Old 29th November 2012, 03:09 AM   #1452
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Originally Posted by Emphrygian Click the image to open in full size.
Component GB
buzzforb - 1
Magsy - 1
vitalica - 2
Reenberg - 1
Emphrygian - 1
qusp - 1
Iancanada - 1
Darn! if only I had waited before buying my parts!!!
I was too quick on the trigger
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 29th November 2012, 03:11 AM   #1453
qusp is offline qusp  Australia
qusp's Avatar
did you really think I would pay full price for anything if I can avoid it?
Old 29th November 2012, 03:16 AM   #1454
bigpandahk is offline bigpandahk  Hong Kong
Do
Me too, I already bought parts for one NTD1 but I can join the GB for my second NTD1
Old 29th November 2012, 03:16 AM   #1455
buzzforb - 1
Magsy - 1
vitalica - 2
Reenberg - 1
Emphrygian - 1
qusp - 1
Iancanada - 1
crazikid - 1
bigpandahk - 1
Old 29th November 2012, 03:27 AM   #1456
pinnocchio's Avatar
LOL, I feel a big slap behind my head
Do
Old 29th November 2012, 04:44 AM   #1457
yeah I did the calcs for the lower voltage, but then you need to make other changes if you want to keep the current up above stock, there are a couple running 2 boards, I havent asked everyones motivations. I have enough unpaid psuedo consultation via email and PM as it is.
it depends on how you are running the mono mode in the ESS, theres 3 different mono modes and you can run with 2 boards, which although larger and more expensive is somewhat neater than trying to piggyback 2 dacs to a single NTD1, which would make for a bit of a mess and longer current connections, which could easily offset any advantage.
its no different to how people are running dual mono with 2 IVY, or 2 Xxx you need to map the dac channels appropriately. so people running dual mono with any of the twisted pear stuff will not change anything when running 2 x NTD1.
i'm running 2, but for 4 channel. which is the advantage of running with 2 boards, you can run dual mono, or you can make a 2 way crossover, either digitally, or by installing active or passive analogue filters in the analogue stages
I still can't figure out how to connect two NTD1 in Dual Mono. According to BIII integration manual, in addition to IVY, it require another Sympatico to combine the two balanced output to single channel.
Old 29th November 2012, 04:56 AM   #1458
What about the enclosure?
Are we moving forward on this?
Old 29th November 2012, 04:57 AM   #1459
qusp's Avatar
nah, OK maybe its not as good as I thought. the BIII FW that is, but if you have arduino, you should be able to do what i'm thinking. its possible with ackodac. you need to play with the channel mapping. dont have time for this sorry mate, this is thinking you should have done ages ago.... i'll help where I can, but you need to pick up the ball here
Old 29th November 2012, 05:08 AM   #1460
Thanks, I will figure it out after I repair the burnt BIII (hoping)!!
A New Take on the Classic Pass Labs D1 with an ESS DacHide this!Advertise here!
Pass Labs S/Ns ? dejanm Pass Labs 8 26th January 2007 07:35 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Copyright ©1999-2017 diyAudio
