A New Take on the Classic Pass Labs D1 with an ESS Dac
Old 17th May 2012, 03:56 PM   #991
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by neb001 View Post
My goodness, what have I started?! I didn't realize my single post would end up starting a trend with my mistake. My greatest apologies to qusp!
incredible isnt it? tbh I dont think it has a lot to do with your post
Old 17th May 2012, 06:16 PM   #992
neb001 is offline neb001  United States
Yeah, probably not but I still laughed when I saw every single person after me had marked +fet.
Old 18th May 2012, 12:47 AM   #993
TrickyMicky is offline TrickyMicky  United Kingdom
@gusp...I appreciate I'm pushing it with the fets but hoping I'll be lucky...:-)
Originally Posted by lm1no2 View Post
sorry
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
4. qusp x 1 this is tentative mate, but wanted to make sure my name was down
5. regal6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
11. Coolhead x1 + fets
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
18. syklab x1 + fets
19. Magsy x 1
20. Vitalica x2 + fets
21. Pinnocchio x 1
22. hochopeper x 1
23. neb001 x1 + fets
24. bigpandahk x 2
25, Jean-Charles X1 +fets
26,iancanada X1 + fets
27. lll X1
28. analog_sa x2 + fets x 2 (shipping to US)
29. savvas + fets
30. lm1no2 x1 + fets[/QUOTE]
31. trickymicky X 1 + fets
Old 18th May 2012, 10:10 AM   #994
TheShaman is offline TheShaman  Europe
I just want fets. Thanks qusp.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 18th May 2012, 02:04 PM   #995
qusp's Avatar
very interesting! dont you think opc?
this I think is that case we were looking for, I reckon you could probably even run dual dacs using that side heatsink with the IV and dac mounted against the wall and bolted securely and still have plenty of room for an eleberate PSU, USB->i2s etc etc and if we band together we can probably get the price down as well as getting customized mounting arrangements and holes like he did for the NCore guys. pretty sexy too IMO
$240 plus shipping
Outside Dimension: W x H x L = 320mm x 216mm x 310mm(12.8''x8.64''x12.4'')
Inside Dimension: W x H x L = 272mm x 192mm x 296mm(10.88''x7.68''x11.84'')
Front Thickness: 10mm
Back Thickness: 4mm
Material: Aluminum
Finish: Brushed, hard anodized
Net Weight: 10kg
Click the image to open in full size.Click the image to open in full size.
Old 18th May 2012, 02:07 PM   #996
qusp's Avatar
I would like somnewhere for an LCD and a larger volume knob area as I have a 50mm thick titanium knob
lol
Old 18th May 2012, 02:32 PM   #997
lwif is offline lwif
I read a lot of pages of this thread but I am not sure of this.
Is the PCB from this GB ok for the buffalo III ?
Thanks for your answer.
Old 18th May 2012, 02:41 PM   #998
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Love that chassis!
Could we have the front panel milled for an LCD? We would just have to specify what type of LCD to get (“Standard” HD44780 compatible LCD 20×4 as an example).
I know this part is a little more complicated...
Do you know what the shipping could be for a chassis of this weight and size?
Anyways, looks really interesting!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 18th May 2012, 03:48 PM   #999
qusp's Avatar
indeed its pretty much perfect for this project as is. still looks like a dac chassis, slick looking and enough heatsink for 2 x ntd1, or 1 x ntd1 with shunt regs for the dac and an i2s/clock and dual dac people theres still easy enough alloy and space around to sink to if you need more. in fact I wouldnt really need an external PSU case with this fella provided we get some internal panels for a second floor. though I may still use an external box for AC just so I can use my cannons somewhere hehe.
the LCD type I had in mind was the one that AR2 used, which is actually a Noritake U
type VFD (Vacuum Florescent Display) , a drop in LCD replacement
like I said, if we can get enough of us, they will customize mounting arrangements, holes etc.
Old 18th May 2012, 03:56 PM   #1000
opc is offline opc  Canada
opc's Avatar
Hi qusp,
I really like it! Having the correct front panel is imperative for me though. I need to have an option for mounting a knob (for ESS volume control), and I'd really prefer if the knob was provided with the front panel so we can all agree on something.
I'd also be up for an LCD, but again, it would need to be standard so it works for everyone.
Owen
A New Take on the Classic Pass Labs D1 with an ESS DacHide this!Advertise here!
Pass Labs S/Ns ? dejanm Pass Labs 8 26th January 2007 08:35 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
