Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th November 2009, 08:36 PM   #21
Default another area of interest
Foobar can convert audio files.
There was a simple how-to located here:
How to use foobar2000 to convert audio files – Simple Help
But I ran into difficulty. I could not locate flac.exe. I could not locate flac.exe anywhere even when doing a full drive C: search.
Sourceforege provided a source for flac 1.2.1 exe. I downloaded that. But here I do not know if there is a specific directory to move this exe.
Foobar asks to locate the flac.exe. from the directory in which my wav files are located.
My wav files are made through a free program called audiograbber. Before it went free I purchased the prog. and never regretted it, ever. Recommended.
So as of now the Foobar convert routine is looking in an audiograbber files directory.
That's enough for this post. I will update if I get it going.
Old 15th November 2009, 09:11 PM   #22
i have it working now. i installed the linear phase free equalizer, it's nice and good sounding to me, but not so easy to control. also the search function for the library is not working, i'm using the dark one, skin, very nice...
Old 15th November 2009, 10:01 PM   #23
Solve is offline Solve  Sweden
Solve's Avatar
You can doubleclick on a dot and push the question mark (?)twice and get "potentiometers".Sometimes easier to work with.
Music is the only art in real time....
Old 15th November 2009, 10:43 PM   #24
wow, very nice, it has almost all functions...
Old 16th November 2009, 12:51 AM   #25
I have made a flac conversion.
Some confusing things are now cleared up. When you get flac.exe from Sourceforge, it auto installs to C: > programs > flac. When that is done pointing to it with Foobar is straightforward. The flac file is saved to the flac directory.
Old 17th November 2009, 01:34 PM   #26
Solve's Avatar
Vst Chainer if you want to use more than one effect.
I use Acon EffectChainer - Effect Rack - Chain VST and DirectX Effects.
You can save your settings with preset.
There are other also like Xlutop Chainer.
Old 17th November 2009, 02:57 PM   #27
solve,
Can you give an example of two effects used together and how to set that up?
Old 17th November 2009, 04:49 PM   #28
Solve's Avatar
You can use this Blue Cat's FreqAnalyst - Real Time Spectrum Analysis Plugin (VST, Audio Unit, DirectX) (Freeware)
last in the chain and check the average frequense if you run a sweep
tone thrue Foobar.
Its not any hightech this one, it just give you an hint.
There are an pro verion also but thats not free...
Old 17th November 2009, 06:58 PM   #29
solve,
I am just asking these things to get a handle on what's available and usage.
To that end, when you say "last in the chain" does that mean an order of loading the plugin or a manner of installation?
At this time I only have any experience at all with the VST plugins. The check boxes for active plugins seems to be limited to one per usage in an either or manner.
Old 17th November 2009, 08:13 PM   #30
Solve's Avatar
I just recogniced that these chainers dont lay the effects in serie as in Cubase.
So my idea with the effects from top to bottom in the chainer dont work.
All are in paralell mode.
So you dont see the Eq settings with the Freq analyst.
You have to activate the plugs so they are green.
The Denon DCM Series CD Player Repair Thread infinitesymph Digital Source 59 14th November 2010 10:51 PM
Trends audio TA-10.1 using the pot VS poweramp mode + foobar volume control grkn Class D 0 26th August 2008 10:10 PM
What do Foobar, J River, etc do better than Windows Media Player (10 or 11)? rick57 Digital Source 9 25th October 2006 05:53 AM
For FooBar users - percy Digital Source 2 21st May 2005 02:16 PM
ASIO with Foobar + M-Audio mourip Digital Source 4 15th October 2004 12:38 AM
Page generated in 0.11844 seconds (77.42% PHP - 22.58% MySQL) with 11 queries
