Anybody using the new ESS Vout DAC (ES9022)?
help with jg filter buffer connections
hi guys,
please verify that i made the right connections based on the attached pic. will be using this with a subbu dac.
Thanks guys,
Guten Tag mein Herr,
Believed the WaveIO was an USB to I2S ! Is it a USB to SPIDF ? or does this pcb provide also this option ?
Ah Ah:D, don'take this ladder, JP should going to have a Heart attack if you swap the 3 resisitors, scratch the gnd layer for soldering 3 uf.l connectors :faint:
Maybe you can Subbuted a Curryman DAC which is I2S at input... could be a spicy ladder !
