Anybody using the new ESS Vout DAC (ES9022)?
Old 4th March 2010, 03:13 PM   #41
ra7 is offline ra7  United States
I can't seem to find the mention of the ess chip in the udac. Jkeny, do you have a source?
I'm sitting on the fence between the super pro and the udac.
Old 4th March 2010, 03:42 PM   #42
jkeny is offline jkeny  Ireland
Banned
ES9022 chip but Nuforce seem to have scratched the ID off the chip AFAIK Have a search in this thread http://www.head-fi.org/forums/f7/fir...if-out-456945/
Old 4th March 2010, 04:20 PM   #43
tritosine is offline tritosine
How's SNR and DNR different? That just doesnt add up. Looks like the DA part has worse thd than the builtin opamp, similar opa365 has thd in ppm range.
EDIT: 98SNR because of the 16/44 usb codec ? -ridicoulus.
- at least they should reveal a level vs thd plot .
Old 27th April 2010, 08:57 PM   #44
EUVL is offline EUVL  Europe
Someone tested a ES9022 modules from me and here is what he has to say :
QA-550 SD card 16/44.1 WAV transport
Patrick
Old 27th January 2011, 11:21 AM   #45
Woodenhead is offline Woodenhead  United Kingdom
Finally got my finger out, and had a listen to this 9022 dac on a little pcb I made...
I read about the 50Mhz local XO for the 9022 the day after I sent the files off for pcb manufacturing, currently using the 12Mhz from the receiver.
I'm using spdif in as I have plenty of spdif sources, using a wm8804 as the receiver.
Excuse the mess on the PCB, I had a duff 8804 initially. Using a simple 3v3 reg for the three 3v3 lines (two for the 8804, one for the 9022)
Very pleasant sound, and driving headphones directly, which is a surprise!
This is the first circuit I've designed myself from scratch, so quite pleased that it works!
Will
Old 27th January 2011, 04:45 PM   #46
Banned
Well done Will.
You will be better served with a lower jitter clock.
Even better served feeding it I2S directly from source
Yes it drives most headphones!
Old 27th January 2011, 09:33 PM   #47
Thanks John.
I've no i2s sources, so went with the wm8804 so that I can give this dac a try. It's a nice, musical sound, way beyond it's price.
I have a 50Mhz XO on the way, and it'll be easy to drop the feed onto the 9022.
Will
Old 28th January 2011, 03:01 AM   #48
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Has anyone had a chance to compare AKM 2496 to ESS 9022? I know it is a long shot but maybe there is someone out there...
www.burningamp.com
Old 28th January 2011, 04:20 AM   #49
Can you get one (AK2496) ?
Patrick
Old 29th January 2011, 12:15 AM   #50
woodturner-fran is offline woodturner-fran  Ireland
Woodenhead: I'm in the same situation as you with plenty of SPDIF sources.... would you have one of your boards for sale?
Fran
Anybody using the new ESS Vout DAC (ES9022)?Hide this!Advertise here!
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 07:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 04:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 01:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Copyright ©1999-2017 diyAudio
