Anybody using the new ESS Vout DAC (ES9022)?
Old 30th May 2012, 06:03 PM   #401
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
OK I got the tip from someone else but thanks to all people that stay with both feet on the ground and like to discover things and share that openly without holding back details.
It's only audio. Member of the non modular PCB design committee
Old 31st May 2012, 07:32 AM   #402
jambul is offline jambul  Belgium
Dear Patrick,
do you know how to use the single d type flip flop with no "not Q" pin?
should i connect the D with Q and take the connection to signal out ?
thank you
denis
Old 31st May 2012, 07:36 AM   #403
samoloko is offline samoloko  Bulgaria
are you guys sure that old system using traditional CS84xx receiver Is not In the same league comparing to new WM8804
can I replace CS8412 In old PCM63 oversampling DAC with WM8804
Old 31st May 2012, 07:39 AM   #404
EUVL is offline EUVL  Europe
I don't know how to do frequency divide without not-Q.
Please kindly google :
Frequency Division using Flip-flops
Patrick
xen-audio.com
Old 31st May 2012, 08:00 AM   #405
Yes Patrick,
I have use google, but mostly the single gate d type flip flop using the "not Q" as feedback loop and devide the frequency by 1/2.
well maybe i need to try harder
thank you
denis
Old 31st May 2012, 08:07 AM   #406
No, you need to have not-Q.
Patrick
xen-audio.com
Old 31st May 2012, 08:14 AM   #407
Thank you patrick,
so i need new single gate d type flip flop then :-)
Denis
Old 31st May 2012, 09:00 AM   #408
Hi Patrick,
can we used the dual d type flip flop instead the single one?
thanks
denis
Old 8th June 2012, 06:09 AM   #409
ryanj is offline ryanj  Australia
Insert impressive title here.
Hi Guys,
In the es9023 data sheet it says best performance will be obtained having at least fs256 for 32k to 96k sampling rates, so it should be fine to use 11.2896Mhz as the master clock.
Has anyone experimented with this?
Is the performance much better using 45.1584Mhz?
Or is it because 11.2896 has a smaller selection of good quality crystals?
Reason being MCK could be fed to a QA550 without using flip flops.
Ryan
Old 8th June 2012, 06:32 AM   #410
My understanding is that the jitter correction inside the ES9022(3) works better with a higher clock frequency.
The datasheet says at least .....
Two FF is easy enough.
But by all means try 11.28 without division and tell us if you hear any difference.
Patrick
xen-audio.com
Anybody using the new ESS Vout DAC (ES9022)?Hide this!Advertise here!
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 08:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 05:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 02:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 08:47 AM
