Anybody using the new ESS Vout DAC (ES9022)?
Old 27th February 2012, 12:38 AM   #351
pidesd is offline pidesd  Canada
pidesd's Avatar
sorry, i meant in my edit above:
thus the 2sk369 has less distorsion than bf862 (for instance) because its CURRENT varies less for the given load and "works less"?
sorry if i mix up things, i just recently began at electronics.
Old 27th February 2012, 12:43 AM   #352
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Sure, you got the point. Summa Cum Laude.
Old 27th February 2012, 12:49 AM   #353
The more horizontal the drain current to drain source voltgae is the higher the ouput impedance of the Fet is. You could also say that it is a good constant current source.
The less the drain current varies with variations of Vds , the less distortion. The cascoding helps anyway because it forces a constant voltage ( more or less ) over the input Fets. My buffer has really minuscule distortion, BF862 or not.
Old 27th February 2012, 12:55 AM   #354
Another thing with this floating cascode buffer is that the voltgae over the input Fet is controlled by the gate of the cascode Fet by sensing the voltage at the source of the input Fet so you have a driven cascode that reflexes changes in voltgae over the input source Fet into the Vgs dynamically.
It looks simpel, but ....
Old 27th February 2012, 02:46 AM   #355
pidesd's Avatar
i ll have to meditate on that. i m not sure i get it all
especially the ''input source fet'' part. i guess you mean it is a near perfect source follower because input fet Vds is almost onstant...?
anyway...thanks a lot for the explanation
Old 27th February 2012, 03:40 AM   #356
It floates on the input signal, but yes, the input Fet sees a constant drain source voltage.
Old 28th February 2012, 11:07 PM   #357
davecandialex is offline davecandialex  United States
Default Dac in US?
Does anyone know where to get this DAC in US either 9022 or 9023?
I emailed Shaw, the US distributir but did not hear back.
Old 1st March 2012, 01:55 PM   #358
samoloko is offline samoloko  Bulgaria
Joachim
what Is your current es9023 dac setup - PS, dac board, output filter
do you use your project design of floating PS - I think It Is much better to use It vs too many pcs of batteries
regards
Old 1st March 2012, 10:28 PM   #359
I am still waiting for the filter-buffer from EUVL.
I use 4 x 9V batteries but i am workuing on a PSU, so not much progress.
Old 2nd March 2012, 10:22 AM   #360
EUVL is offline EUVL  Europe
Our team member who is taking care of the buffer has a serious family emergency which we cannot forecast how long it might take.
He has our fully moral support, and the team reassured him that hobby is at this moment of no importance.
If Joachim does not want to wait, we can send you a couple of PCBs, which will be with you in a week or two.
But you would have to match your own FETs, and acquire the inductor from Mouser.
Thank you for being patient with us.
But we have maintained, and will also in the future, that this is only hobby.
There are things in life that deserves much higher priority.
Patrick
xen-audio.com
Anybody using the new ESS Vout DAC (ES9022)?Hide this!Advertise here!
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 07:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 04:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 01:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Copyright ©1999-2017 diyAudio
