Go Back   Home > Forums > Source & Line > Digital Line Level
Old 8th March 2013, 04:49 PM   #571
It's a Sennheiser HD480 classic (100Ohm). On Monday i'll test with Sennheiser HD650 and compare with electrostatic phones from Sennheiser with HEAD acoustics PEQ V with PVA IV.3 (it's a bit unfair ).
Best regards, Daniel
Old 8th March 2013, 05:05 PM   #572
EUVL is offline EUVL  Europe
You can also use the ES9022 to drive a 100~200 ohm phone at normal or low listening level.
But it won't drive a 32ohm Grado or an AK701.
It will still make sound, but I would not call it music.
Else why do I need to bother with the DAO SE .....
Patrick
xen-audio.com
Old 8th March 2013, 05:05 PM   #573
Default Headphones vs V
I'll ask the stupid question, will the output of this FET stage {into headphones} increase with V? More slam? Daniel may still be running 9Vx2... yet.
I find that on "hot" recordings I have to turn down the digital volume on ES9023 or it clips [even at 3.6V with 100K to ground on pin#6]. After that it's a wonderful DAC chip for the price! I am anxious to try the filter buffer, I have one filter 90% done in a AC wiring box [just the filter] to experiment with in front of other gear I own, and after some DACS, obviously.
Old 8th March 2013, 05:08 PM   #574
No. Follower has no gain.
Patrick
xen-audio.com
Old 13th March 2013, 03:02 PM   #575
diyskat is offline diyskat  Australia
I wonder if anyone with access to proper measurement equipment could run and publish some performance measurements for Daniel's board (THD+N, IMD, DNR etc.) ?
Old 13th March 2013, 08:52 PM   #576
That would indeed be quite interesting However the first betatester just received their proto-boards and it may take some time until they sourced the components and soldered the boards.
I already did some first measurements with my build but did not save the graphs (Arta Demo -> only screenshots). With my RME DIGI 96/8 PAD I measured a THD+N around 0.0058 (-103dB) with 96kHz I2S Input (not U.Fl but pinheader) from miniSTREAMER (TE7022) *. Hard to interpret though since there are too many variables. I don't have a low THD generator at hand to test the ADC of the RME card. In loopback (incl. soundcards DAC) THD is (only) slightly better.
*There might also be some potential to improve the miniSTREAMER or asynchronous USB solutions might also be better
Old 14th March 2013, 12:09 AM   #577
Thanks Daniel. It does look promising. I would still love to see someone run a similar testing methodology like nwavguy did for the ODAC. I know it is a long shot to ask as it would require time and access to a professional grade equipment. If your BOM is finalized and replicable, the test results could provide a good indication of what we can practically achieve with the board.
BTW, are you planning to give this specific board a code name?
I think I'm going to get one piece to try out. Just worried about replicating that ES9023 soldering feat in your photo.
Old 2nd April 2013, 12:31 PM   #578
Hi Curryman,
I arrived here from your thread over in the mini DSP forum.
Where are you at with this board? sound like just what I'm after to use with the new minisharc board and then out to my hypex modules.
Stefan
Old 2nd April 2013, 03:03 PM   #579
Orangeart,
the build-thread you seek is at:
Build thread for ES9023 + JG Buffer boards (betatest)
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 07:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 04:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 01:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Copyright ©1999-2013 diyAudio
