| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#391 |
50MHz is max for ES9023.
So you'll have to use 33.8688 MHz XO. Patrick
xen-audio.com |
#392 |
Thanks, Patrick for the offer. I certainly know the time problem. I took some days off from designing and that did me really good.
#393 |
thx for reply Patrick
can I use ES9023 at 16.9344 or It Is better to go higher as It can to 50 MHz |
#394 |
As high as possible in synchronous mode.
Patrick
xen-audio.com |
#395 |
diyAudio Moderator Emeritus
I think you mean asynchronous mode ....
It's only audio |
#396 |
No. I meant synchronous mode.
That is why I use 45.1584MHz XO which is divided by 4 to clock the QA550 also from the same XO. If his CD player use 16.9344 and can be fed the CLK signal externally, he should then use 33.8688MHz XO. He can then divide by 2 to get 16.9344 for the CD, while the ES9022 operates at 33.8688. No such game for WM8804. SPDIF always involves a PLL I am afraid. ![]() Patrick
xen-audio.com |
#397 |
Hi I misread the previous posts (without WM8804)
BTW I am very happy with WM8804, no more existing CS84XX or DIR products for me anymore unless a new one will be developed that surpasses WM8804/5..
It's only audio Last edited by jean-paul; 30th May 2012 at 03:44 PM. |
#398 |
The last sentence I can agree with.
![]() Thanks go to fitzfish for the tip. Patrick
xen-audio.com |
#399 |
What tip ? To use WM8804 ?
It's only audio |
#400 |
Yes.
xen-audio.com |
| Balanced jfet buffer for Vout DAC? | jonners | Solid State | 7 | 22nd October 2010 07:57 AM |
| where to connect + wire for Vout? | jarthel | Power Supplies | 2 | 27th March 2007 04:49 AM |
| Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V | Groundloops | Power Supplies | 14 | 16th February 2007 01:13 PM |
| help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er | jarthel | Tubes / Valves | 9 | 30th May 2006 07:47 AM |
