Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th February 2012, 04:15 PM   #331
Joachim Gerhard's Avatar
Good, we have the link now. In fact my filter can be redesigned for 3rd order too if so desired without much effort.
Old 6th February 2012, 10:40 PM   #332
I built Joachim Gerhard buffer / filter over the weekend and listened to it for few hours on Sunday. Sounds good and I like it. Will play around with it for some more time. I used the Fastron Inductor from mouser.com.
Thanks!
free2dev
Old 6th February 2012, 11:36 PM   #333
Thanks, that is good new, so the Fastron works. What happens if you jumper it ?
I made some simulation on a 3rd order filter but i can not make it phase linear without drop in the treble with the default 4,7nF cap. I like the second order better anyway. I really listened careful so that it does not take too much sparkle and air away.
Old 7th February 2012, 01:36 AM   #334
Hi Joachim, I haven't tried it. I will jumper it when I get home and see how it sounds.
-free2dev
Old 7th February 2012, 02:22 AM   #335
Fine, i am curious.
Old 7th February 2012, 02:58 AM   #336
EUVL is offline EUVL  Europe
We are still waiting for delivery from Mouser.
Joachim, no problem changing the 4.7n cap if necessary.
Patrick
xen-audio.com
Old 7th February 2012, 06:01 AM   #337
I made some simulations and the price of the 3rd oder filter is more latency or an undershot of the impulse response so i stick with the second order filter. What could be tried is to lover the "ballast" resistor before the buffer and then we could use a lower inductance coil with potentially higher self resonance but then we load the DA converter more and that gives more distortion. I really do not want to go under 10kOhm or the buffer makes not much sense. I think my solution is as good as it gets, all considered.
Old 7th February 2012, 03:57 PM   #338
Our PCB just arrived.
As you can see, it accommodates up to 4 JFETs in a cluster per channel.
And the layout is nearly fully symmetrical.
Matching and building during the weekend, then we shall send to Joachim for audition.
Patrick
xen-audio.com
Old 7th February 2012, 04:15 PM   #339
Wow, that was fast. Looks very good. I will listen to it carefully.
I just made some improvements to my system that have to do with more precise and transparent volume control plus new speaker placement, so i am in a better position now.
Old 24th February 2012, 10:39 AM   #340
I was requested by PM to give an update for the Joachim gerhard buffer.
We have the PCBs as you can see. We matched the BF862's.
But before we could match the J111, the team member involved has a family emergency.
That has taken him out of hobbies for the past 2.5 weeks.
As you would all appreciate, work and family come first for us.
I cannot give you a date as to when that situation would be relieved, such is its nature.
So I can only ask for your patience in the meantime.
Patrick
xen-audio.com
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 07:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 04:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 01:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Page generated in 0.09125 seconds (77.08% PHP - 22.92% MySQL) with 11 queries
