Anybody using the new ESS Vout DAC (ES9022)? - Page 20 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th June 2011, 07:14 PM   #191
buzzforb's Avatar
I can get the new 9023 from a local distributor. If there is interest in group buy, let me know.
Old 26th June 2011, 07:22 PM   #192
EUVL is offline EUVL  Europe
Great idea.
More people can then try out for themselves.
Patrick
Old 26th June 2011, 08:29 PM   #193
massimo is offline massimo  Italy
If anybody from EU needs few 9023s, PM me
Old 28th June 2011, 10:53 AM   #194
Hello
I've received yesterday the data sheet for the ES9023
Looking at it and at the application diagram, page 7, they don't say a lot about implementation.
I presume that the xtal oscillator goes at the MCLK pin of the ES9023 ?
Which sound better between synchrone and asynchrone mode and how do we set it on the ES9023 chip ?
Thank
Bye
Gaetan
Old 28th June 2011, 08:17 PM   #195
has anyone measured a DAC with 9022? Only measurements that could be found are those of uDAC V2 - and those are not very nice.
Tomáš
Old 30th June 2011, 03:58 PM   #196
The THD measured less than .005% and the zero noise was <15uV on the first layout I did. I cannot yet measure signal to noise and dynamic range, need an upgrade to my analyzer.
Dave
Old 12th July 2011, 11:25 AM   #197
Patrick
do you measure any difference In thd and noise between standard modules of receiver pcb with 12 MHz and DAC pcb with local 50 MHz XO shown Anybody using the new ESS Vout DAC (ES9022)? and the same modules but receiver pcb fed with 12 MHz from 48 MHz XO at DAC pcb divided by 4
Old 9th September 2011, 02:33 PM   #198
I want to buy ES9023
Old 19th September 2011, 06:11 AM   #199
Alexium is offline Alexium  Ukraine
How much do they cost (ES9022, 9023)? I can't find a single online shop selling them.
There is a general consensus that Iout DACs (with proper output stage) outperform Vout ones (ceteris paribus). I don't know why that should be so, but still. Are these ES DACs competitive in comparison with equally priced Iout DACs?
Old 19th September 2011, 06:44 AM   #200
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The price I heard was around $2. But there might be an even better sounding option available now from TI - the PCM51XX. Worth a listen anyway, especially with its 'low latency' filter engaged. Those parts are around the $2 mark too, potentially both are quite a bargain vis a vis sound quality per dollar spent.
The reason that Iout DACs might sound better is because the analog stages can be optimised rather than constrained by the process technology used for the rest of the IC.
Iout DACs of the latest generation are in general more expensive than Vout ones - probably for marketing reasons. Their volumes are lower but the perceived value is higher amongst audiophiles. You'll need to go back a few generations to find bargains in Iout DACs - I'm currently playing with TDA1387 and find that very much to my taste. Cheap too.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 08:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 05:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 02:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 08:47 AM
Copyright ©1999-2017 diyAudio
