Anybody using the new ESS Vout DAC (ES9022)? - Page 15 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th May 2011, 03:55 PM   #141
EUVL is offline EUVL  Europe
I presume you have the ES9022 IC, so you already have the data sheet.
If you study the pictures of post #54 carefully, you should not have too much difficulty figuring out what component values I used.
For SMD, start with data sheet value.
I do not want to encourage you to copy me blindly.
So you should not be afraid to try things out.
> I would ask to further describe the frequency divider (which flip-flop did you use?)
Any high speed single gate will do.
I used one from On-Semi. But NXP or TI is also OK.
> which XO Crystek CX3391
Will do fine.
> did you use a 0.1uF C0G cap at the S/PDIF input (pin 20) of the WM8804?
Yes.
Enough hints ?
Patrick
Old 3rd June 2011, 09:48 PM   #142
Hi All,
well at last I got the chance and headspace to sit down and compare EUVLs 9022 dac to my Pass D1 clone. The 9022 was the one described by EUVL here and here is my implementation. I used my shigaclone player throughout as a comparison (it is my best digital source). This means 16/44 only of course....
So, this was interesting. Firstly, it was noticeable that the EUVL dac plays a bit louder than the Pass, so I needed to change volume when swapping over to level the field a bit. The EUVL dac is so clean, it definitely offered greater resolution and more firmer better defined bass. I regularly use a couple of Henri Mancini tracks as test tracks. They have lots of percussion going on, plus massed strings and are recorded with fantastic dynamics. Comparing the 2 dacs, you could easily hear more going on with the EUVL dac. Things like the echo in the room, or where 2 percussion instruments are being hit at the same time - you get both, even when they are sitting together in the soundstage. Now, the Pass still gives very close to this, but overall the tone from it is warmer. I can imagine that this would appeal to many. However you argue for that though, the bass on the Pass is not as well defined or firm I think. Maybe some fancier caps on the outputs might clean that up a bit (it certainly helped on the Xono).
My next task now is to use a source thats not as good as the shiga - something that doesn't resolve just quite as well. Maybe my squeezebox or something. That should be interesting. My impressions are that the EUVL dac is absolutely revealing and transparent - GIGO would definitely apply I think. But feed it a good line, and it really will shine. This really is quite the piece of kit!
Fran
Old 4th June 2011, 03:39 AM   #143
Hi, the es9022 looking real interesting and I am thinking of replacing the tda1543 inside my tweaked deq2496 with the es9022 via I2S of cause. Can anybody point me the way to order a ES9022 board. Thanks.
Old 4th June 2011, 04:38 AM   #144
One very happy customer !!
Fran,
If you would ever get a chance to listen to Jonners' QA550 (or Koon's Ultimate Source 2) with a 45.1584 MHz ES9022 in synchronous mode, you would agree with me that there is still more to be had from a very simple, very low total cost digital source for 16/44.
Patrick
Old 4th June 2011, 03:26 PM   #145
Thanks Patrick.
My other choice is to cannibalize a 2nd hand Nuforce uDac, but might be a bit of a waste to just use the es9022.
Old 4th June 2011, 05:51 PM   #146
Hi Patrick,
The differential version looks cool. Could you hear or measure the LSB error induced on the inverted side?
Thanks,
Dave
Old 5th June 2011, 04:54 AM   #147
No, but if you are really bothered, there are circuits around to correct for that, I think.
Patrick
Old 5th June 2011, 10:51 AM   #148
jkeny is offline jkeny  Ireland
Banned
Fran,
Patrick
Patrick, a while back Fran & a number of people did briefly hear one of these - an ES9022 connected via I2S from a QA550 board. It had no mods to it & the local QA 11.xxx clock was the MCLK used. This was auditioned through headphones. Unfortunately it died when we tried connecting it to his main rig - never did understand what happened to it - both the ES9022 & QA550 were taken out?
Old 5th June 2011, 12:23 PM   #149
jonners is offline jonners  United Kingdom
jonners's Avatar
My QA550/EUVL-ES9022 is still playing happily. The DAC is installed in an Al box directly underneath the player. I've tried it in my main system and I recently took it on holiday in conjunction with a small portable system. I could play it in the car too, but I haven't tried that yet.
Old 5th June 2011, 12:32 PM   #150
My own combo must be playing as long as, if not longer than John's, in my GC system in the study.
Never any problems.
But then also never put the ES9022 directly to a headphone either.
Patrick
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 07:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 04:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 01:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Copyright 1999-2017 diyAudio
