| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
I had heard such for the ad1853...
Ben. |
#12 |
TimS, temperature of Q1 Q9(and other pairs) will be different becouse Q9 dissipate less power then Q9 so the voltage at the input stage will be different from zero (20-40mv), so it should cascode Q1, such as I did in this old design http://diyaudio.org.ua/blog.php?u=2&b=6
In addition, the discrete output for the DS DACs will be a bad idea because it would occupy too much space on the PCB and therefore catch too much interference. 1794 Offset removes simply by adding 2.4k resistors from -15v power supply to 1794 outputs.
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua |
| Differential Amplfiers - current sources under/over the triodes | audiowize | Tubes / Valves | 34 | 27th January 2012 02:50 PM |
| Voltage Differential Amplification | Stee | Solid State | 60 | 12th August 2008 08:54 PM |
| Direct WM8816 to differential current output DAC | panson_hk | Chip Amps | 4 | 27th June 2007 05:03 AM |
| max. differential voltage in an Aleph P | rsbay | Pass Labs | 1 | 28th February 2005 08:31 AM |
| Page generated in 0.06731 seconds (67.30% PHP - 32.70% MySQL) with 11 queries |
