| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
With the TDA1545A, how should one handle Vref?
From the TDA1545A datatasheet, it's supposed to be fed to the (+) input of the I/V opamp; I_out gets the (-) input . Most DIY designs for TDA1545A seem to ignore Vref, leaving it dangling (see Examples below). This goes against Philips' recommendation. So, what's the real deal with Vref? (P.S. If you don't have experience with TDA1545A, how about TDA1543?) Thx! Examples: Rbrorer TDA1545A I/V ...and... Peufeu's TDA1545A I/V:
#2 |
My guess is that if Vref isn't 2/3 VDD then there will be DC offset at the op-amp output?
And if the non-inverted input is connected to ground, the op-amp will be outputting positive voltage all the time? That would be bad. |
#3 | |
Your second point is why I raised the query to begin with. But that (not using Vref) is what some DIYers seem to be doing for discrete I/V. Here, again, are examples of this: Single rail, active I/V for TDA1543, TDA1545A http://peufeu.free.fr/audio/extremis...plement_4.html The first one seems to have been primarily designed for the TDA1543, tho' Rudolf does note (almost as an afterthought) that it works for TDA1545A. It does and it sounds fine (I have built it!). But I keep wondering about the dangling Vref. Is this a fundamental part of Philips' design -- or just an afterthough tweak? Is there any way one can use it in the discrete (non opamp) ckts noted above? Last edited by hollowman; 30th August 2009 at 08:43 AM. |
#4 |
the current output from 1545 must be with potential from 2 to 4V for 5Vpower supply, better 3.3v, resistor from power supply to Iref pin sets midscale output current and full scale output current.
In your schematic potential on current output 1545 will be 0v, input impedance of such i/u stage will be very big, all this is very very bad. The principle of CC DAC is described in "A Self-Calibration Technique for Monolithic High-Resolution D/A Converters" by D. WOUTER J. GROENEVELD, HANS J. SCHOUWENAARS, HENK A. H. TERMEER, ANDCORNELIS A. A. BASTIAANSEN i uploded it here http://www.diyaudio.org.ua/viewtopic.php?f=20&t=205 PS sorry for my bad english
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua |
#5 | |
I use a TL431 adjust to 3,3 volt ( with capacitor 47µF from input TL431 to + rail ) This seems me the best. |
#6 | |
Hello sigurd,
The sound quality of the TDA1545A is directly dependant on how you drive IREF pin. In my Jundac Five DAC kit, I use a reference tension with very low output impedance to drive IREF pin. From Diyaudio.com: IREF, the secret of the TDA1545A |
#7 | |
Instead of the 11K resistor from + rail ( 3,3 volt TLE431 ) to Vref ( 7 ) a BC550c emitter follower : on the basis of the transistor a capacitor and parallel a resistor to ground : MKP? , PIO ?, TANTALUM,? Output emitter voltage can set by this resistor . The quality of the capacitor affects very much the sound. I try an capacitor direct on the Vref pin , but that seems me not so good. BTW your DAC is splendid, also the I/V conversion, simple but very effective. Thanks for your help. |
#8 | |
10µF oscon, 220µF BG and with a bead. |
#9 | |
Hi sigurd,
In my personal experience, the ferrite bead degrade audio rendering. I forget this solution in analog section. |
| Opamp for Vref on TDA1543, TDA1545A | hollowman | Digital Line Level | 2 | 24th August 2009 10:10 AM |
| SAA7323 Vref pin? | jnewbold | Digital Source | 0 | 16th September 2008 03:35 AM |
| Tda1545a vref capacitor | ash_dac | Digital Source | 34 | 10th January 2007 11:39 AM |
| Passive I/V Vref | dsavitsk | Digital Source | 4 | 22nd November 2005 03:07 PM |
| AD580 2.5 V very low noise VRef | jackinnj | Swap Meet | 0 | 2nd September 2002 03:11 PM |
| Page generated in 0.15356 seconds (69.58% PHP - 30.42% MySQL) with 10 queries |
