| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi guys,
My dac is giving a output of 0.3v for a 0dB 1khz. Is it too low and what is the effect down stream, beside having to crank up the vol? Thanks, KK
CD pro=>TDA1541AS1=>Lightspeed=>ESP crossover=>Soraya CB205=>Accuton drivers |
#2 |
I assume you mean 0.3Vrms which would be 0.85V p-p. It all depends on your DAC supply rails so this might be reasonable for a 1.8V rail DAC. As long as the DAC is achieving the 96dB signal-to-noise that 16bit digital aspires to you should have no problem with adding clean gain.
I have seen 1Vrms as a more typical 0dBFS level. Care to share the DAC schematic and we could comment further. |
#3 |
Hi Iain,
Yup, it is 0.3Vrms. As for the circuit, it is a TDA1541A to a I/V 34ohm resistor to step-up transformer. It has a output impedance of 4.5kohm. My intention is to put a unity non-inverting buffer after that. Cheers, KK
#4 |
Hmmm. Doesn't seem like it's stepping up much. Sounds like it may be mismatched somewhere. Do you have full specs on the transformer like primary inductance, turns ratio etcetc?
#5 |
From my measurement, the voltage after the I/V is 0.043Vrms. Hence, the transformer is a 16.9dB gain. I don't have much info on the transformer.
KK
#6 |
Oh yeah, it is an input trans for a tube amp.
Cheers. KK
#7 |
43mVrms is about right for 4mA pk into 34ohm so that's encouraging.
Without a schematic and measurements it's hard to say how it works.
#8 |
The DAC is a simple I2S to the TDA1541A to the passive I/V. Nothing complex about it. The only thing that I thinking is to leave it alone with a low line out or change the value of the I/V or change to a higher step up trans.
Thanks Iain. KK
| DC Voltage on RCA Output | baxtr | Parts | 7 | 16th January 2009 11:37 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 06:17 AM |
| eqt with low output voltage | marko | Car Audio | 6 | 2nd January 2007 01:19 AM |
| use D1 I/V with voltage output dac | poolorpond | Pass Labs | 6 | 11th June 2006 08:47 PM |
| P27 Output Voltage | rayban68 | Solid State | 0 | 6th October 2004 07:19 PM |
| Page generated in 0.08848 seconds (75.74% PHP - 24.26% MySQL) with 10 queries |
