| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 |
I found the MP3 and checked it out.It was a nice thing to listen too.
But for my application the problems aren't nearly as bad as the DAC and amp are in the same case sharing the same star ground (Output stage has a completely separate supply) Also there is a metal case to protect from outside RF. So im only getting the signal from the processing board to the amp board (probably going to put a sheet of metal between to shield the D-class EMI) |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 08:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 04:12 AM |
| Creating a differential signal from a single-ended signal for bridged amps | Peter Daniel | Chip Amps | 45 | 8th November 2004 01:47 PM |
| ALEPH P signal select and volume control | Ritz | Pass Labs | 3 | 21st April 2004 02:54 PM |
| Volume control + Single Ended -> Differential Amp | koolscooby | Solid State | 2 | 6th April 2004 12:50 AM |
| Page generated in 0.06616 seconds (67.12% PHP - 32.88% MySQL) with 11 queries |
