cs8414 & wm8740 dac (one dac chip) - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th August 2009, 06:27 AM   #21
sparkle's Avatar
Kurt - thnx for the reply
o.k. i can cut down the frequenca range (down to 20 or 30kHz) using LPF but i would not like to have one opamp more.. it is enough that i have one in I/V conversion inside the chip...
heheheh
o.k.... do You think LPF on the output of the dac (before the tube stage) should be o.k.???
Old 12th August 2009, 06:27 AM   #22
sparkle's Avatar
(double posting - sorry guys)....
Old 12th August 2009, 06:27 AM   #23
sparkle's Avatar
(double posting - sorry guys)....could not delete the posts.. don't know why....
sorry again...
Old 12th August 2009, 07:02 AM   #24
sparkle's Avatar
schematic of the tube stage.....
Old 12th August 2009, 07:11 AM   #25
Kurt von Kubik's Avatar
Send a message via MSN to Kurt von Kubik
heheheh
The DAC chip does not necessarely include an op-amp just bcause it is a U out DAC chip.
I think the WM8740 might feature a switched capacitor anti aliasing filter, which natviely makes it a U out chip. So you can find u out chips both with internal I/V conversion devices, and i.e CS4398 which is a u out chip without any I/V conversion.
Old 12th August 2009, 08:55 AM   #26
sparkle's Avatar
o.k. - but basically the tube stage schematic should work like posted ... right??
Old 20th August 2009, 06:19 AM   #27
sparkle's Avatar
i had a report from a friend of mine that tube stage might not work together with the dac... i asked the guy who tested the tube stage and he confirmed that the circuit together with the dac should work fine.... any further opinions...?
Old 26th March 2012, 11:15 PM   #28
borizm is offline borizm  Poland
Default WM8740 not need any LPF
Originally Posted by Kurt von Kubik View Post
You definately need to post filter the output from the WM8740.
It is a very noisy DAC, and on top of that, it performs better with post filtering. Wolfson Micro recommends a lowish 20 KHz LPF for the device, to meet their standards.
Maybe, but I had to remove all the filtering capacitors from LPF at the output of WM8740 to get a proper sound.
OPA2132 works very very fine without LPF capacitors, creating unbalanced signal to discrete headphone amp which also hasn't got any LPF filter.
Old 28th March 2012, 02:10 PM   #29
terranigma's Avatar
BBs chips, as they only need smoothing of the analog signal. Most other chips are musch more noisy, as it is the working frequency of the DAC or antialiasing filter, that has to be filtered.
Have you any experience with AKM dacs such AK4396? If you include Vout dacs to your statement above, of course.
Problem DIY DAC / WM8740 ah79 Digital Line Level 7 14th March 2009 06:20 PM
WM8740 spare _atari_ Digital Source 2 20th August 2007 02:33 PM
CS8414 Cirrus Logic chip? Mrstereo Parts 0 27th March 2007 08:32 PM
wm8740 takashi Digital Source 11 23rd July 2003 10:26 PM
Copyright 1999-2017 diyAudio
