cs8414 & wm8740 dac (one dac chip) - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th August 2009, 08:31 PM   #11
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Hi I had a quick look at your circuit and a few problems are clear.
1. CS8414 pin 16 is an output and needs to be tied to either 0v or VCC otherwise it will float and could draw lots of power. I suggest 0v (it sets what is output on other pins but since your not using them it shouldnt matter)
2. You have shown no power supply decoupling on your Sch. This part will not work correctly without it. You need at least a 100nF cap on both the digital and analogue power supply pins and I would recomend a 10uF can in parrallel with the 100nF as shown in application diagram. Do not think because it is digital it does not need a good power supply. Phase locked loops are very sensitive to power supply, get it wrong and it may not lock or you will get lots of jitter.
3. You have no reset circuit on the CS8414. It will work most of the time however it may operate strangely on occasions if it comes up in an odd state. The reset circuit is shown in the data sheet and basically takes all the mode pins high at the same time. (M0..M3) it achives this usign an OR gate so that the mode can be set at other times. It will probably work without this and I have seen other circuits without it, but you can't be sure.
4. Ensure that the filter components are close to the CS8414 and that the ground returns straight back to the AGND pin. If you get this wrong you will get lots of jitter.
5. For good performance you may need a double sided pcb. If you cant do this then some copper tape on the bottom side connected to ground will help.
6. SPDIF input needs a return ground, it can't float as if you have a transformer at the other end with no ground you will have no ground referance. So connect the Rxn side of the 75R to ground.
7. You have the same decoupling issues on the DAC. Each power supply pin needs a 100nF cap in parrallel with a 10uF cap. These parts are critical to the sound quality of the DAC and it is worth optomising them once it is built as the DAC seems to be sensitive to the characteristics of the caps used here. Ensure the the ground return paths are as short as possible.
8. On the VMID rails it appears that the two caps do not return to teh same ground. If so this is a mistake. VMID also needs 10uF caps, sounds rubbish without and THD is compromised quite alot of current is drawn from these caps in pulses.
9. Pin 27, 26 should be high for no deemphasis (most CDs dont have deemphasis) any that do will sound like the trebble has been turned up. You can wire the SPDIF reciever up to do this automatically but its quite complicated.
10, pin 25 should be wired high to unmute the output. or connected to a switch if you want a mute.
11. Pin 23 should be wired high for I2S 24bit, you may as well use this as any unused bits are filled with 0 anyway.
12 cCearly you will need an output filter. I would filter using an opamp stage and get it working before trying to do anything with valves.
13 You have not shown any PSU for this circuit. Thw WM8740 is very dependant on the quality of the power supply so I would put the regulators on the sam PCB and close to the WM8740 to keep the impedance of the supply as low as possible.
That should be enough to get you going. Good luck.
Andy.
Old 11th August 2009, 06:18 AM   #12
sparkle's Avatar
gfiandy.... thnx for the kind reply...
1. i was using CS8414 without conecting pin 16 to low or high before in my TDA1543 dac... it was working fine... no problems occured... no unusual currents detected... locked every time - and is still workign with very good sound coming out of it...
2. power decoupling - you are completely right - i am using decoupling a lot... every psu has a decoupling but it is not shown on the sch attched - it is a revision one of the sch... just to ask questions and get some answers... my bad - forgot to draw it...
3. reset circuitry... well, i don't have it in my TDA1543 dac and it worked fine every time - in few dac's i build.... no problems were detected.... i will think about it... thnx...
4. filter is close to the cs8414 on the pcb....
5. double sided pcb is a problem... can't do it... i have to use single sided....
6. Rxn to ground - ouuupsss... forgot to draw it... you are right - it is going to ground...
7. same as no. 2.
8. VMID's are going to the same ground....
9., 10., 11. pins will be connected to insure 24bit I2S without deemphasis...thnx for the tip - i was reading the datasheet but do not have the table i draw for the pins' right now... i made it adjustable on the pcb just in case i misunderstood anything... thnx...
12. i'll try without the fitering first... if the sound is bad i will decide upon filtering.... thnx...
13. psu has two LM317 regulators (one for digital and one for analogue)... after that i use shunt regulators with TL431 (that worked nice in TDA1543 dac) to regulate the voltage to 5Vdc and 3.3Vdc that i for powering the receiver and dac....
i tried to make separate grounds - one digital and one analogue and i will connect them on input/output connectors (or, as an option, on one point on the pcb using a jumper....)...
i have a lot of jumpers on the pcb - this is not very good but i am trying to cut down the costs and to have a nice dac.. that is nearly impossible i am aware of it but still......
i will attach the current verion of the pcb and schematic - as soon as i update the sch....
comments are welcome
gfiandy ... thnx again for the time and effort... much appreciated..... thnx again...
Old 11th August 2009, 07:23 AM   #13
sparkle's Avatar
current sch of the dac... psu sch still needs to be done....
Old 11th August 2009, 07:29 AM   #14
sparkle's Avatar
pcb with parts...
Old 11th August 2009, 07:31 AM   #15
sparkle's Avatar
pcb - no parts.... only traces and smd parts...
Old 11th August 2009, 07:32 AM   #16
sparkle's Avatar
some of the coupling cap's are 100nF and some of them are 220nF.... it is a bit different in sch and on pcb... pcb is a reference....
every coupling cap is X7R multilayer ceramic....
Old 11th August 2009, 08:17 AM   #17
sparkle's Avatar
psu sch....
Old 11th August 2009, 08:18 AM   #18
sparkle's Avatar
psu pcb with parts...
Old 11th August 2009, 08:19 AM   #19
sparkle's Avatar
psu without parts...
Old 11th August 2009, 08:31 AM   #20
Kurt von Kubik's Avatar
Send a message via MSN to Kurt von Kubik
You definately need to post filter the output from the WM8740.
It is a very noisy DAC, and on top of that, it performs better with post filtering. Wolfson Micro recommends a lowish 20 KHz LPF for the device, to meet their standards.
The only DAC chip I know of, that could be used with no or at least a very low slope filter is BBs chips, as they only need smoothing of the analog signal. Most other chips are musch more noisy, as it is the working frequency of the DAC or antialiasing filter, that has to be filtered. This noise can be as loud as only 10-15 dB below full scale at all times and typically @ several hundred KHz. This can result in amplifier clipping even at very low listening levels. As listening level is increased you might even burn your speakers without hearing any sound from them.
When filtered you also need a buffer, or else the characteristics of the filter might change with load.
If you do either as Gfiandy or the application notes sugests, the matter will be solved.
Problem DIY DAC / WM8740 ah79 Digital Line Level 7 14th March 2009 05:20 PM
WM8740 spare _atari_ Digital Source 2 20th August 2007 01:33 PM
CS8414 Cirrus Logic chip? Mrstereo Parts 0 27th March 2007 07:32 PM
wm8740 takashi Digital Source 11 23rd July 2003 09:26 PM
Copyright 1999-2017 diyAudio
