Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th November 2012, 01:50 AM   #571
acko is offline acko  Australia
Originally Posted by qusp View Post
acko, I dont know that you have made a mistake with writing that out, or not,
is 1USD = 0.93AUD that translates to 1AUD = 1.0752... better than 1.04
thanks for the tip on the interstate fees! wth! why? whats the bloody excuse for that? it costs them nothing and there is no interstate tax
Yes, Qusp you are right my mistake actually. Just the reeling Aussie dollar and the seller transaction fee increases! Thank you very much.
Don't know how I got it all mixed up
AckoDAC Project
Old 20th November 2012, 07:22 AM   #572
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by AR2 View Post
What is SEN I/V? If you have a link I would love to see it. In my set up Legato is just a small portion of the full I/V. There is Lundahl transformer and jFet buffer behind it, but in separate case, see here:
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
You may find the SEN I/V thread here.
Others and myself have found that replacing the Legato (even tweaked extensively) with the SEN I/V is the single best upgrade you can do to your ES9018. The circuit is exceedingly simple, but require 4 floating supplies if run in a balanced configuration (highly recommended). The high number of supplies seems to scare people of from trying this circuit, but if the ultimate in sound is what you are here for then it is an absolute must.
Especially for somebody like you who well know the superior quality of well implemented JFETs for audio.
I don't know anybody who has turned back
2SK1530/2SJ201 sales thread and FET list
Old 20th November 2012, 08:27 AM   #573
Default SEN IV
Many thanks NicMac, will be considering this also, newer mind the complexity if superior sound is the benefit
AckoDAC Project
Old 20th November 2012, 08:31 AM   #574
Default Super Transport AKT
Originally Posted by hochopeper View Post
Acko, curious minds in Brisbane want to know more about this AKT!
Rumours had been milling around via email, very interested to see what you guys come up with!
Still rearranging the design. Ian's FIFO-Clock on the way also. Will be posting some details soon ...
AckoDAC Project
Old 20th November 2012, 09:02 AM   #575
gwikse is offline gwikse  Norway
Very interresting. If the community allow you to build a "finished" solution based on those designs then I know that I am _very_ interrested indeed. Too complex for me to try to build on my own.
Edit: Acko; let me know if you want / allow me to create 3d models of your components. Could be nice to allow custom case work.
JRiver MediaCenter 18 | .... DIY ..... | Nordost Heimdall | AP Virgo V
My sketchup models
Old 21st November 2012, 12:02 AM   #576
Acko, I'm just stirring the pot there mate. I think this will be a VERY interesting design indeed. I am watching with interest as things develop. I am not in a position that allows the financial commitment of a fully tricked out AKD12P design at the moment, so I am just watching mostly, for now.
I suspect you aren't alone there!
Old 21st November 2012, 01:54 AM   #577
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
NicMac,
thank you for the info. Interestingly, when I checked SEN I/V I found a lots of similarity with the balanced jFet buffer I am using. Essentially similar building blocks. In my system I have Legato and after that balanced jFet buffer with Lundahl transformer. That means that I could eliminate Legato and modify my buffer to serve as I/V converter as well. Maybe. I will check with Dr. Zen Mod to see what he thinks.
www.burningamp.com
Old 21st November 2012, 03:47 AM   #578
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
now that would be cool, only problem is, you would have to work out some way to have it in the same case, doing IV in a separate case from the dac doesnt seem like a good idea to me anyway
Old 21st November 2012, 04:38 AM   #579
Master Burner
AR2's Avatar
You are correct, honestly did not think about that one, but still I believe I do have a room for that if I pull out Legato. I am bringing anyways two channels of power supplies from two Shuntys, so at least that is not an issue, but what maybe that is not needed since batteries are also required... Need to think more about it, but for sure would like to test and observe the difference. Will be interesting.
www.burningamp.com
Old 21st November 2012, 08:04 AM   #580
Default DSD Connections
Originally Posted by Bunpei View Post
Dear Acko,
When you are ready to integrate SDTrans to your TURBO Master Clock board in a synchronous master clocking scheme, I will support you as much as possible. As SDTRans is designed to accept external master clocks from the first time, you will find it easy to change its hardware configurations. Even if you break any part of the transport board, I am sure Chiaki will repair it without any problem.
Bunpei
Hi Bunpei,
Thank you very much for your continued support!
I am actually preparing to test the SDTrans384. The Turbo Clock is directly compatible, so minimal mods required. But first I need to get an interface board done that will take the header outputs of the SDTrans and fan out to w.fl coax to match the AKD12 Digital Inputs.
This is almost ready but I have noticed that when physical connections are arranged for DSD from SDTrans, the DAC inputs will not be compatible with I2S (stereo mode). This means I cannot play pcm audio on a DAC setup for DSD and vice versa, unless the digital inputs are physically reconnected to match. The line of contention is LRCK (of I2S) that becomes DSD1 and also the way the DAC cells are connected to the inputs.
Not sure if I am getting confused with all the signal lines but any help is most appreciated.
AckoDAC Project
WM8816 based pre-amp panson_hk Chip Amps 13 22nd May 2009 02:16 PM
DIY ESL III (based on an ER Audio Kit) jasonlky Planars & Exotics 7 23rd January 2008 07:09 AM
UCD based amp oldmaelstrom2 Class D 3 27th June 2007 10:10 AM
Copyright ©1999-2013 diyAudio
