ackoDAC based on ES9018
Old 8th November 2012, 08:52 AM   #551
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Originally Posted by qusp View Post
they are the same polymer caps used throughout the ackodac stuff. lowest Z on the market afaik. the Panasonic SP-Cap (Special Polymer)
looking good AR2! one thing though mate, make sure you dont make the analogue current output connections too long so you can have short i2s connections. I wopuld hazard a gues that a few cm extra w.fl cable will damage the sound less than a few cm extra twisted pair analogue cable
Thank you for suggestion Qusp. What I did not show in these shots is that on the regulator side of the board, where two longer 6/32 screws are sticking out, that is where Legato I/V board is going just slightly above the regulators. That is why those screws are long. It is parallel to the DAC board, which also provides minimum distance between the two boards. Twisted wires shown in the shoot I left at that moment longer, because Legato was not installed yet, but when I finished I shortened them to the shortest possible length. That is the beauty of this mechanical design that everything is very close to each other. My I2S W.FL wires are 60mm each. And MCKL U.FL as well. Analog wires are about that as well. When I am done I will post complete pictures. I did a lots of thinking and several iterations of the design. This configuration works perfect for dual mono, only for that regulators are on the front of DACs, and two DACs are back to back. Still it gives the smallest footprint. Also added benefit is with Legato board, that has resistors that are operating with fairly high temperature. In vertical position, they are above transistors on the board and close to the top, which provides maximum cooling.
www.burningamp.com
Old 8th November 2012, 09:01 AM   #552
Master Burner
AR2's Avatar
Originally Posted by hochopeper View Post
I'd be tempted to twist all of the power supply leads together too ... as in each pair twisted together rather than all running parallel like they are at the moment.
Otherwise that looks really, really nice! Given me some ideas about the next iteration of my case layout too.
I am glad if you could find my work helpful. It is not easy packing it all together and closest to each other. Thank you for the suggestion regarding wires, and sure makes all the sense
www.burningamp.com
Old 12th November 2012, 05:15 AM   #553
Master Burner
AR2's Avatar
Here is the implementation of whole DAC board and I/V stage.
www.burningamp.com
Old 12th November 2012, 05:18 AM   #554
qusp is offline qusp  Australia
qusp's Avatar
excellent! a little beyond what the makers of that case had in mind i'm sure
Old 12th November 2012, 05:27 AM   #555
Master Burner
AR2's Avatar
Hehehe, it is way better than what was in. Although, mechanically, it is a great design. The top and side cover is one heavy piece and it slides in through the rails on the side. Just two screws from the rear tighten two stops so that cover cannot slide back and that is it. One of the best designs I have seen.
www.burningamp.com
Old 12th November 2012, 06:43 AM   #556
NicMac is offline NicMac  Italy
NicMac's Avatar
Looks great! There is even space to replace the Legato with a SEN I/V to take it to the next level
Old 12th November 2012, 07:48 AM   #557
gwikse is offline gwikse  Norway
That looks amazing. Great work MR. AR2
I am hooking up my own Noritake CU20045 – UW5J inspired by your project later on (waiting for a second arduino controller to test with). Migrating to Acko dac`s next time out as well.
JRMC (PC) / ROON (RPI-ROONbridge) | .... DIY ..... | Nordost Heimdall | AP Virgo V
Old 13th November 2012, 01:35 PM   #558
Master Burner
AR2's Avatar
In order to avoid to be redundant, and yet to provide readers of both threads with final pictures, here you will find images of the completed project, and some more info on evolvement of I/O, buffer boards and crossover.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
www.burningamp.com
Old 13th November 2012, 01:43 PM   #559
Master Burner
AR2's Avatar
I am hooking up my own Noritake CU20045 UW5J inspired by your project later on (waiting for a second arduino controller to test with). Migrating to Acko dac`s next time out as well.
Thanks Gwikse.
For Noritake VFD, it is pretty much the same like using regular LCD, but you will have to provide a separate 5V power supply for it. As far as I remember it takes around 250 mA, and you do not need brightness adjustment pin from Arduino. Noritake is pin to pin compatible to standard LCD.
www.burningamp.com
Old 13th November 2012, 01:48 PM   #560
Master Burner
AR2's Avatar
What is SEN I/V? If you have a link I would love to see it. In my set up Legato is just a small portion of the full I/V. There is Lundahl transformer and jFet buffer behind it, but in separate case, see here:
www.burningamp.com
ackoDAC based on ES9018Hide this!Advertise here!
DIY ESL III (based on an ER Audio Kit) jasonlky Planars & Exotics 10 3rd July 2017 06:04 AM
WM8816 based pre-amp panson_hk Chip Amps 13 22nd May 2009 02:16 PM
UCD based amp oldmaelstrom2 Class D 3 27th June 2007 10:10 AM
