| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#411 | |
AckoDAC Project |
#412 |
Hi Acko and all,
How would I go about connecting the ackodac in 4 channel quad mode? I have the 8 channel version. I will be connecting it to the exa transport via i2s. Also, as far as register settings, what are the optimal settings for my configuration? I want to run with the ASRC and oversampling on. thanks, Will |
#413 |
#414 |
Sometimes a square peg fits a round hole just fine
nice work gillib! good to see another ackodac out in the wild
#415 | |
Thanks for sharing. fantastic effort!. If I am not mistaken this DAC board is a special build with a 9018 chip instead with outputs combined in stereo. Also, looking closely your SDATA from transport goes to only one input of the DAC. The original manual indicated just this but I have since update manual as below: "Stereo PCM I2S sources have 3 signals, Bit Clock, Word Clock and DATA. The Bit Clock (BCK) goes to 'CK', Word Clock (LRCK) to D1 and DATA to D2, D3, D4, D5 of the Digital Inputs of this DAC module." So you are loosing dynamic range and output level with only one input connected. Sorry I did not update you on this but I did post on the above sometime back. Will send you the updated manual.
AckoDAC Project |
#416 | |
www.hifiduino.wordpress.com |
#417 |
Of course, yes, the undocumented feature of the 9018/12 Sabre chips. Thanks GLT.
AckoDAC Project |
#418 |
@acko and glt
Thank You for Your precious information. I will change that. Special thanks to glt for his work concerning the Sabre DAC, his homepage is extreme valuable. Bruno |
#419 |
Hi GLT,
How would I set the register for 8bit quatization, as that is the way I would like to implement my quad set up. This sets up register 15, but how does this differ-compare to the reg 14 setting that is documented for ackodac? Do both of these give me the input sharing? Can I use one or the other or both? Does quatization also give me better noise characteristics? I would then combine the outputs 1,3 2,4 5,7 6,8 ? thanks, Will |
#420 | |
Quantizer is reg15 Rerouting is reg14 Both will result in using 1/2 the inputs, but only 8 bit quantizer will turn off 1/2 of the internal digital logic. This "lowers out of band noise". You can do both with no harm You can read more here: Sabre32: Effect of Quantizer Setting H i F i D U I N O PS: I don't claim to know the theory of what is going on internally. Just collecting and passing along what others have said and when I can, I test it too :-)
| WM8816 based pre-amp | panson_hk | Chip Amps | 13 | 22nd May 2009 02:16 PM |
| DIY ESL III (based on an ER Audio Kit) | jasonlky | Planars & Exotics | 7 | 23rd January 2008 07:09 AM |
| UCD based amp | oldmaelstrom2 | Class D | 3 | 27th June 2007 10:10 AM |
| Page generated in 0.12355 seconds (78.51% PHP - 21.49% MySQL) with 11 queries |
