| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#201 | |
Regulator boards are available now. I will post updates here also. Regards, Acko
AckoDAC Project |
#202 |
Acko,
From what I understand, the full package (and supposing that the regs will be bought in kit form...) should well reach the USD 1300 mark... At this point, I would be grateful if I could have some clarifications regarding the questions here below: 1. What is the height of the PSU boards? 2. Do you think that the chosen chassis should be well ventilated? 3. Will all sub units be dispatched from Australia? 4. What will be your accepted methods of payment? And, 5. Is the I/V stage based on op amps? If yes, which ones? Thanks and Regards, |
#203 |
is choosing a less facetious title...
sorry misunderstanding. right, there is no high current shunting going on, so moderate ventilation should be provided, but I would not say lots of it, depends on which output stage you choose. if you choose the opamp I/V the OPA1632 is the wide soic variety which has a heat sink/pad on the underside, normaly OPA1632 do actually get quite warm, but still not much compared to mosfets etc. the height with it all stacked should not much exceed the height o the large heatsinks on the PSU I wouldnt think, even the 2 (or 3 with I/V) story stack of dac board and regs would not be overly tall. so I would think 3-4 inches would be fine
the PSU units, regs and dac are all very well integrated, so the ciurrents are chosen to match each next stage without too much overshoot, this will also keep heat to a minimum Last edited by qusp; 15th April 2010 at 03:15 PM. |
#204 |
also the I/V stage can be balanced OR single ended; the XLR version is based on OPA1632 only, the single ended version has additional AD797 to sum the outputs
#205 |
with the akc I2S how a the digital vol. control used? do i just need a pot and that s it?
#206 |
Banned
Remember this board is designed as a board for experimenters so all the individual supplies are independent - no assumptions were made about which supply was not of importance & can be overlooked (these assumptions have been made in the past & proved to be wrong). It is completely open to the builder, what supplies they use & how they might combine them. Now that the current requirements of each supply pin is known it is possible to decide which PS/regulators will suffice. Sonic considerations are another factor, however.
#207 |
yes i agree.
i edited my post because i though the kr3312 was 50$ my mistake |
#208 | |
Regards, Acko
AckoDAC Project Last edited by acko; 16th April 2010 at 09:14 PM. |
#209 | |
Th AK PSUs, Regulators, DAC amd IV are all matched and runs cool if set up as shown in my previous post. Other combinations need to be tested and ventilation provided accordingly. Currently all shipped from Australia. On-line ordering only, Paypal or credit card. Version of IV stage shown is IC OpAmp based as explained by 'Qusp' but there will be more options available in future from other contributors to this project. Regards, Acko
AckoDAC Project |
#210 | |
Banned
I have detailed the full package below (AFAIK) - please correct if there are errors: DAC $250 - fully assembled MCU $100 - Premium version Voltage regs $340 - set of 6 I/V $100 - SPDIF input $55 PS supply $175 Total $1020 Last edited by jkeny; 16th April 2010 at 09:19 PM. |
| WM8816 based pre-amp | panson_hk | Chip Amps | 13 | 22nd May 2009 02:16 PM |
| DIY ESL III (based on an ER Audio Kit) | jasonlky | Planars & Exotics | 7 | 23rd January 2008 07:09 AM |
| UCD based amp | oldmaelstrom2 | Class D | 3 | 27th June 2007 10:10 AM |
