| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#181 |
Hello Acko,
Will you be offering bare boards only as well? Perhaps I would go into these rather to reduce international shipping costs a bit and get the most of the parts locally... Thanks. |
#182 |
Yes, these are available for those wish to iron out things themselves. The site is new and will put this options soon. In the meantime enquire about custom options.
AckoDAC Project |
#183 |
Hi Acko,
I am definitely interested. Very probably in a complete set of the necessary modules... Cheers and keep up with the good work! |
#184 |
As I told you in pm I'm very interested in building this DAC, but with an USB input only. Is the MCU module designed for this use ?
#185 |
Banned
#186 | |
John (Jkenny) is handling the USB-I2S module and will update with more details.
AckoDAC Project |
#187 |
Banned
Thanks Acko,
As I PMed to Zaireeka: The USB module that will be offered with the AckoDac is based on the modified HiFace 24/192 asynchronous USB transport that I've offered elsewhere as a stand-alone USB transport. It will plug into the input of the AckoDac feeding it I2S signals (not the inferior SPDIF). This means high quality, high res USB audio is available directly with the AckoDac The options, pricing & testing of this module has yet to be finalised so please bear with us a bit longer |
#188 |
Thanks for the answers.
#189 |
couple questions:
-can one AKR3312 supply the entirety of the dac without problem for those who dont want to shell out 600$ in one shot like me? -is only one prduction run going to be made and that s it, so that you better buy what you want right now? - do you have some kind of test results for the regulators and current/voltage capabilities or things like that? maybe one could be interested in using these in other projects. Last edited by pidesd; 12th April 2010 at 10:42 PM. |
#190 | |||
Banned
Combined 1.2V supplies 130mA Combined 3.3V supplies 90mA I'm not sure the max current output of the KR3312 but will check. Remember though that the Sabre DAC is VERY sensitive to power supply quality & to get the best from it requires some separation of supplies & the best quality that can be provided. Quote:
| WM8816 based pre-amp | panson_hk | Chip Amps | 13 | 22nd May 2009 02:16 PM |
| DIY ESL III (based on an ER Audio Kit) | jasonlky | Planars & Exotics | 7 | 23rd January 2008 07:09 AM |
| UCD based amp | oldmaelstrom2 | Class D | 3 | 27th June 2007 10:10 AM |
