Tda1545 d1 i/v stage - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 4th July 2009, 07:26 AM   #1
Default Tda1545 d1 i/v stage
Can anyone suggest me a good iv stage for tda1545?
I have read d1 iv stage.
But i dont find people use it for 1545 just tda1543.
What kind of adjustment should i make to make it work on tda1545?
Old 4th July 2009, 12:33 PM   #2
Andypairo's Avatar
I used in my earlier DAC the D1 with the TDA1545A.
Since both the TDA1545 and the TDA1543 use a single 5V supply you can use it in the same way, just keeping in mind that the output voltage of the Iout pin should stay between the compliance boundaries specified in the datasheet.
Ciao
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 5th July 2009, 12:28 PM   #3
Ciao
Andrea
so i just connect my dac to the d1?
no parts changes or remove in the dac?
Old 5th July 2009, 10:04 PM   #4
jkeny is offline jkeny  Ireland
Banned
I think the DAC connection to D1 needs to be at 5V (or is it 3.3V), I can't remember - it's in the datasheet
Old 6th July 2009, 07:24 AM   #5
how to make it 3.3v?
should i remove the passive i/v reistor too?
Old 6th July 2009, 08:23 AM   #6
hollowman's Avatar
Default Re: Tda1545 d1 i/v stage
Two versions of "Jocko"-style designs come to mind:
(1) Peufeu's Case 6 and its improved version 8a
(2) rbrorer's I/V.
I've used (2) with good results.
Adjustments:
- the current demands of the 1545 are low enough that one can use an opamp, biased into class-A, for supplying Vdd.
- read the datasheet and follow its advice on Vref. You can also use an opamp here, too.
- bypass everything real well
Personal bias: use a good oversampling digital filter with this DAC [hint: I ain't a fan of NOS!]
WTB TDA1545´s figge77 Swap Meet 0 28th May 2009 11:45 AM
Pass D1 I/V for TDA1545 AudioLapDance Pass Labs 5 5th February 2009 01:03 PM
I am looking for tda1545. yangsmm Swap Meet 0 17th October 2006 06:16 PM
WTB: a few TDA1545:s hifi Swap Meet 5 25th July 2006 05:41 PM
Anyone know about TDA1545's output? eVITAERC Digital Line Level 4 20th March 2006 05:47 AM
Copyright ©1999-2017 diyAudio
