Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd July 2009, 04:49 PM   #1
Oystein is offline Oystein  Netherlands
Default Capacitors for PCM1716 DAC chip
I am tweaking my NAD 524 cd player as much as possible.
I already installed a Tentlabs clock; Burson Op-Amps, replaced signal capacitors and all this was already a big revelation to me.
Now I am going a step further going troug the powersupply and more.
There is one subject I have to ask your opinion / experience:
The analog out from the DAC chip has the signal ground EXTL and EXTR connected to ground by a capacitor. (pin 11 and 18)
I can imagine that the quality of this capacitor can influence the output signal.
There is very little space around but if I want to fit a MKT in there it must be smaller value (2,2 uF instead of 10 uF).
Does anybody know the exact funtion of these acapacitors ?
The 10 uF are now standard miniature Elco's.
Any feedback is highly appreciated.
Thanks, Oystein
Old 2nd July 2009, 08:01 PM   #2
Fenris is offline Fenris  United States
Looking at the datasheet, it looks like they're related to the low pass filter for the analog portion of the DAC's output. I'd recommend bypassing (not replacing) with a 0.1 to 1 uF film cap. The bulk capacitance is needed for frequency response, but can be improved with a bypass cap. Solder to the underside of the PCB if there's no room to make it fit.
Listen to the music through the stereo, not the stereo through the music.
Problems with PCM1716 blu_line Digital Source 0 30th June 2006 10:18 AM
replacing pcm1716 with wm8740 ?? mekanoplastik Digital Source 12 10th August 2004 07:00 PM
decoupling PCM1716 Smiffy Digital Source 6 6th February 2004 01:24 PM
PCM1716, is it any good? mcai7et2 Digital Source 4 17th December 2003 04:36 PM
PCM1716 in differential mode wmincy Digital Source 3 28th September 2003 07:55 AM
Page generated in 0.07672 seconds (70.28% PHP - 29.72% MySQL) with 11 queries
