NOS Dac stacking
NOS Dac stacking
Old 3rd June 2009, 07:31 AM   #1
Jeffrey Davison is offline Jeffrey Davison  United States
Default NOS Dac stacking
1541's and 1543 nos chips I've seen in multiple stacked arangments in dacs.
My question is this...
can the AD1865 chip be stacked? has anyone already done so?
Jeff Davison
Old 3rd June 2009, 01:36 PM   #2
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Every chip that has Iout can be stacked.
But be sure to know which pins must be paralleled and which ones must not.
Old 1st April 2012, 01:09 AM   #3
gupsta is offline gupsta  United Kingdom
I too am interested in this, how it might be acheived, has any tried it already ? I'm guessing its going to be more complicated than the tda1543 towers ?
Old 1st April 2012, 02:41 AM   #4
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
As Bernhard points out, you can stack the AD1865 if you're using the current outputs (that's pins 4,21). Don't use the internal opamps, choose a suitable external I/V stage. I'd not parallel the Trim and MSB pins (2,3, 22 & 23) or the internal opamp connections (6,7,8,17,18 & 19) but all other pins should be good to stack.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 1st April 2012, 03:27 PM   #5
SoNic_real_one is offline SoNic_real_one  United States
Definitelly stacking would have to leave out the internal OpAmps and the trimming part. The cips work with nothing connected to trim terminals.
Now... in my experience (PCM61P) trimming reduced visibly (on spectrum analyzer) the 2nd and 3rd harmonics - it was like 4-6db for each. Didn't really took screen grabs so don't hold me to it.
I think is more than stacking up to 4 can do.
Old 1st April 2012, 08:09 PM   #6
Thanks, this is the schematic for the DAC and DOS. I'm guessing I would need to change some resistors.
https://skydrive.live.com/?cid=6a26b...D70C940478!150
Old 1st April 2012, 08:29 PM   #7
Yep, the trimming option is not used anyway.
The resistors series with data signals would have to be reduced (even zero is OK). The I/V stage with resistor is crap IMO, but definitely paralleling the IC's with reducing the value of resistor would help.
BTW: At U5, -ROUT is incorrect connected.
Old 3rd April 2012, 05:32 AM   #8
alfa147x is offline alfa147x  United States
once you get your final schematic figure out would you mind if I used it to create a DAC?
Old 7th April 2012, 09:12 AM   #9
It's not my schematic, I purchased the dac off ebay.
NOS Dac stackingHide this!Advertise here!
Stacking Heil AMTs diamondsouled Planars & Exotics 9 23rd February 2016 02:25 PM
Stacking Opamps?? fmak Digital Source 4 13th August 2004 08:02 AM
“Stacking” Toroids??? Jan Dupont Parts 2 10th June 2003 10:47 AM
Core Stacking fr0st Parts 1 20th March 2003 10:07 AM
Stacking toroids - Ok? harvardian Solid State 23 11th September 2002 06:40 AM
Copyright ©1999-2017 diyAudio
