diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Line Level (http://www.diyaudio.com/forums/digital-line-level/)
-   -   $40 USB to I2S converter (http://www.diyaudio.com/forums/digital-line-level/145093-40-usb-i2s-converter.html)
sharpi31 31st May 2009 09:27 PM
Wow - this seems cool.
EBAY $40 USB to I2S
Any thoughts?
sharpi31 31st May 2009 09:36 PM
Compatible dac with I2S input?
I2S input CS4398 dac
Should these two components offer reduced jitter compared to other USB dacs?
theAnonymous1 31st May 2009 10:41 PM
This has the same USB receiver as the first device. If the CM108 outputs I2S directly to the CS4398 then using this with the Teralink would be redundant.
riktw 31st May 2009 11:07 PM
pcm2706 does the same trick.
gmarsh 4th June 2009 04:04 PM
The 12MHz TCXO in this thing accomplishes absolutely squat. The CM108 IC still has a crap CMOS PLL onboard which generates 44.1/48KHz audio clocks, and the audio clock is ultimately derived from the rate which the PC is pushing samples at this converter.
$40 for the whole thing in a box (including a TCXO which costs about half that price in low quantities) is actually a great deal if you value the sum of the parts. But this isn't a high-end piece of equipment or anything.
So there's my armchair evaluation :D
dublin78 16th June 2009 09:33 AM
Does anyone have any new experience of these?
erin 12th July 2009 04:09 PM
I've got one.
It sounds great. Get one if you can.
I used to use the Behringer UCA-202 for USB- SPDIF conversion.
This unit is so much better with more detail all round.
I cant recomend it enough! and the price is good.
contact teradak direct:
teradak888 at hotmail.com
I fogot to say that, I can guarantee that this is a "high end" piece of equipment. No worries about that!
Copyright 1999-2017 diyAudio
