Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th May 2009, 04:16 PM   #1
tomat is offline tomat  Indonesia
Default digital interface transformer,help
can i directly replace the coupling capacitor on input dac ,usually 0.1uf with digital interface transformer such from audio note?
thanks ,hope anyone can help
cheers
Old 29th May 2009, 12:20 AM   #2
the coaxial input coupled with 0.1uf mylar capacitor to inverter ic tc74hcuo4ap ,i plan to replace that 0.1 mylar with digital interface transfrm
help please
thanks
Old 4th June 2009, 02:19 AM   #3
Cliff45 is offline Cliff45  United States
I'll bet this capacitor is simply used for "DC Blocking" in this application, because a excessive amount of DC bias voltage could cause any noise present on the input line to false-trigger the Toshiba TC74HC04AP CMOS inverter chip. I believe that this chip is more than likely being used as a "input buffer" for the S/PDIF input circuit, but I don't have the board schematics to look at so I am just stating the most obvious use of a chip like this one in a digital input circuit.
You should take a look at the web pages on the Scientific Conversion Inc. web site for more information on the various trade-offs of designing circuits with pulse transformers as inter-device coupling isolators. There are three papers in PDF format that are exceptionally good reading on this subject!
http://www.scientificonversion.com/
The links are on the lower part of the column on the left side of the main page.....
HTH-
Old 4th June 2009, 05:10 AM   #4
Thank very much for the info Mr Cliff
Digital interface chips lt cdr data Digital Source 0 16th June 2008 08:44 PM
Proper digital audio interface de_zeurkous Digital Source 12 17th November 2007 07:00 AM
Which of these digital interface schemes would be best ? percy Digital Source 4 13th April 2006 11:41 PM
Another digital transformer/interface question ble0t Digital Source 11 30th April 2005 03:38 AM
digital interface higrade Digital Source 3 16th January 2003 12:35 AM
Page generated in 0.08681 seconds (72.90% PHP - 27.10% MySQL) with 10 queries
