| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1 | |
Banned
How about a new group project - something like what the Shigaclone did for transports, I believe this could do for PC audio - an inexpensive way to realise high quality audio from a PC.
First off Asynchonous USB is a big deal - it avoids the clock jitter problems that plague USB audio by using the clock in the USB device to synch the PC USB. This avoids the usual scenario where the PC clock is used as the timer for the USB signal. So, there are only a few products that operate in this mode from Wavelength & Ayre &?. Why because the development of the drivers for Windows is a big task!. This development has also been done by Tascman for their inexpensive Pro audio portable recording products Tascman US-122L & US-144. ($120 & $150). Steve Nugent of Empirical Audio already uses this Tascam unit (modded) along with his Pace Car reclocker(which provides the low jitter clock) as a solution for I'm guessing > $1,000 Quote:
- first change the internal clock to a low jitter type with a low noise PS (not one of those Chinese clocks) - run the unit from a clean external PS supply rather than the USB PS - maybe tap into I2S signal to feed an external DAC So for possibly < $200 (depending on clock costs, etc) we get - a very low jitter USB audio DAC The standard unit can be found here: http://www.tascam.com/products/us-144;9,15,70,16.html The internal chip IDs & pics can be found here and mods look very do-able: http://www.everholt.org/abel/tascam/...144_chips.html Does anybody have one of these Tascam units and/or a service manual? Edit: Oh forgot to say the Tascam will do 24/192 also! |
#2 |
Banned
Read more about Empirical Audio's use & mods of the Tascam here: http://www.audiocircle.com/index.php?topic=64017.0
#3 |
The Tascam looks like a terrifying box of junk. I would rather desolder the only two chips needed and rebuild using proper power supplys and clock. Still, it may be a solution if you are really dedicated. Thanks for posting it.
#4 |
Banned
What are the only two chips needed - the uC & the USB chips? Don't need the AKs Digital Interface Receiver chip?
#5 |
That's the way it looks. If one could bust the read protection of the Atmel you can use a micro of your own choice too
![]() The DIR/DIT chip appears to convert to and from spdif and that is probably where you can tap the I2S from. I don't see any need to keep it if you don't need an spdif output. |
#6 |
Pardon my ignorance, but lets say that I needed to keep the Tascam (because the recording features are quite useful for me), and wanted to swap out the clocks for better crystals, is it just X1, X2 and X4 that I need to swap out? Thanks
| Asynchronous reclocking | Ulas | Digital Source | 62 | 24th January 2006 08:19 PM |
| Has anyone actually measured Elso's Asynchronous Reclocker? | pop11 | Digital Source | 5 | 17th March 2004 02:09 PM |
| Asynchronous reclocking problem | Andypairo | Digital Source | 11 | 23rd December 2003 09:46 AM |
| Asynchronous Clocking | weinstro | Digital Source | 0 | 12th June 2003 05:31 PM |
| First attempt at asynchronous reclocking | Oli | Digital Source | 2 | 25th May 2003 12:38 AM |
| Page generated in 0.08139 seconds (83.00% PHP - 17.00% MySQL) with 10 queries |
