| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 |
Banned
I've modded my 01US starting here: M2TECH Hiface USB->SPDIF 24/192Khz asynch
#22 |
I am listening to the IO-USD hooked to my M-Audio “Superdac” for a month now. This is by far the best I have heard so far with a DAC connected through USB (including the DacMagic). Although the E-MU sounds pretty good, it has still some uneasy edgy sound with longer listening. This is completely absent with the IO-USD – Superdac combo. This combo sounds very natural, open and with ease without any listening fatigue.
The Superdac is unfortunately not available/in production anymore for a long time. I have modded this thing in the past with a better external low noise stabilised PSU and better NS-LME op amps. I see no use for a separate 5V for the IO-USD. My laptop has already a lo noise 5V on the USB port and the IO-USD is isolated from my audio set through the S/PDIF transformers, which are of pretty good quality. It are no cheap Chinese ones but Murata ones also used in pro gear (although made in China |
#23 |
Banned
Hi Pjotr,
You can check how low noise PS on the laptop compares to your laptop running off batteries. I have found the Musiland DAC to repond well to my mods as I have detailed! |
#24 |
Hi Jkeny,
I have done so (it is an Asus EeePC 901 netbook) and I don’t notice any difference. The 5V has its own smps inside the EeePC. What amazes me is that, despite the standard Crystal S/PDIF receiver chip in the Superdac, measured jitter with a 11025 kHz test signal, is very low for a S/PDIF link: > -135 dB. But the Superdac has a dedicated input with a separate comparator and doesn’t use the comparator of the Crystal chip. Also I don’t notice any difference when driving the IO-USB through ASIO or Direct Sound (WDM) with my JRMC music player. The drivers of the IO-USB work flawless with both. This was also a bit problematic with the E-MU drivers. |
#25 |
Banned
Very good Pjotr
#26 |
Maybe worth to mention is that the 5V of the Crystal S/PDIF receiver of the M-Audio Superdac is very sensitive to noise. With the standard wall wrath I get a whole bunch of 50 Hz (and its harmonics) related spurs in the jitter plot. These completely disappeared after I powered it with a good filtered and stabilised external PSU and did put some better (and bigger) Lo ESR Panasonic FC caps nearby the receiver chip.
| Musiland Lilo 3 - 24/96 USB to SPDIF? | Kane Williams | Digital Source | 15 | 21st August 2008 01:14 PM |
| Musiland SRC10 upsampler for sale | chengtaw | Swap Meet | 3 | 16th May 2008 12:12 PM |
| Musiland DAC 24/192 for under AU$400! any good? | OzMikeH | Digital Source | 2 | 16th June 2007 08:38 PM |
| SPDIF on cdrom to SPDIF on Digi Crossover | davidallancole | Digital Source | 0 | 11th January 2007 04:26 AM |
| cdrom spdif quality / sound card spdif | metebalci | Digital Source | 0 | 2nd September 2006 08:16 PM |
| Page generated in 0.09570 seconds (73.80% PHP - 26.20% MySQL) with 11 queries |
