How to build a tubed I to V converter ?
Old 4th May 2009, 08:16 AM   #1
Yvesm is offline Yvesm  France
Yvesm's Avatar
Default How to build a tubed I to V converter ?
The most common way is to loop the output of an opa to its inverting input.
Could this be implemented with tubes ?
Attached is what grown in my head last night.
My guesses:
First triode is CCS loaded for max gain.
Thus, it's Rk( R2) does not need to by passed.
2nd one is a self biased vy Hi z CF.
R3 being bootstrapped, C1 does not need to be large.
The negative supply allows for the cathode to be set
at ground potential eliminating the need for an
additional link cap at output.
R1 is the earth of the circuit lowering input
impedance to (I guess) zero to acheive I to V behaviour.
How far am I from truth ?
Thanks for any better suggestions.
Yves.
Old 5th May 2009, 08:16 AM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
The opamp I/V converter you referred to works by inserting the current into a 'virtual earth' terminal. The inv input is at virtual earth because of the feedback (the feedback keeps the inv input at the non-inv input level and that is normally grounded).
So with tubes you should follow the same principle: inject the current into the cathode of the tube and use feedback to keep the cathode at (ac) ground.
Edit: You can do it open loop also. Inject the current into the cathode, put the grid at (ac) ground with the right DC bias for the tube bias current, load the anode with a CCS, pick off the signal from the anode via a cap or go to another level-shifting stage to get down to ground level.
The way your idea is, now the current is injected into a high-impedance node and the i-output of the DAC (which should stay close to ground) is now going to be relatively high voltage level.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 5th May 2009, 08:51 AM   #3
Guido Tent is offline Guido Tent  Netherlands
Jan Didden
Indeed, inject at cathode. Now, to lower input impedance:
Put cathode signal also differential amplifier with other input grounded, connect output of that diff amp to grid of input triode (and assure feedback takes place rather than feedforward)
best
Guido Tent
www.Tentlabs.com
Old 5th May 2009, 02:31 PM   #4
lcsaszar is offline lcsaszar  Hungary
What about an LTSpice model of these ideas?
Old 5th May 2009, 03:29 PM   #5
Yvesm's Avatar
Just cos I'm unable to modelise the tube I plan to use
If someone know : 6AQ4 / 7536 / EC91 , thanks in advance
Yves.
Old 5th May 2009, 06:41 PM   #6
On Hiatus
SY's Avatar
Yves, I don't have a SPICE model, but I could certainly send you a 6AQ4 to check.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th May 2009, 04:55 AM   #7
Yvesm's Avatar
Hi Stuart,
TNX2U, but I've 4 at hand
It just happens that the tracer is in "revamp mode" for some weeks
How to build a tubed I to V converter ?Hide this!Advertise here!
Tubed IR spectrophotometer 7n7is Equipment & Tools 17 21st November 2009 04:23 PM
Tubed HU EvilGenius Car Audio 5 26th May 2006 09:54 PM
Can anyone help me to build a Optical in to USB out converter? wf1318 Digital Source 3 11th February 2006 05:11 AM
I Want To Build A Very High Quality A/D Converter BillyJoeJimBob Digital Source 25 6th August 2004 07:40 AM
Tubed-out guitar affects guitargully Instruments and Amps 3 7th March 2004 07:09 PM
Copyright ©1999-2017 diyAudio
