Need help to indentify zener diode c3v0ph
Old 3rd May 2009, 12:42 PM   #1
Chilli6565 is offline Chilli6565  Australia
Smile Need help to indentify zener diode c3v0ph
On the schematic I am using for this zener it clearly states it is 8v2 ( 8.2 volts, naturally )...but on the zener it says c3voph..which to me is 3.0 volts?.
It is an Audio note dac two ( circa 1997 ) ....the schematic I have is for a dac4...but The cct's look mostly identical to me ...
The schematic is floating around here somewhere...I will try and post it soon for all to have a look at.....the zener in question is just after the 7805 reg which supplies the digital board.
" Digital is only ac anyway "
Old 4th May 2009, 05:23 AM   #2
Smile interesting!
found it !
Old 4th May 2009, 07:35 AM   #3
Mooly's Avatar
It's 8.2v and what a strange circuit ( if you don't mind me saying ).
The 8.2v has 5 base emmiter volt drops added to it, in other words 8.2 -(0.7*5) give or take. Absolutely bizzare.
Negative rail is the same.
Old 4th May 2009, 07:47 AM   #4
Smile hhhmmmm
Hi Karl....how u been...you helped me with another post a while back..it was a cal dac with a dc offset prob and no bleeder resistor, which u fixed.
Anyway, to the problem at hand...yes looks a bit odd...so does that mean you can confirm c3v0ph is an 8.2 volt zener, as that is what is marked on the zener and it came out of the cct marked 8v2 on the scematic????...if I measure from one side of the zener ( with it back in the dac ! ) to zero volts , should I get 8.2 volts??.
thanks
Old 4th May 2009, 07:49 AM   #5
Default ooops
correction...it is marked c3v0ph on the zener....hence my confusion....
Old 4th May 2009, 07:51 AM   #6
Mooly's Avatar
Hi, Im fine thanks,
Just read across each zener on volts with it working and should be 8.2 ish. The tolerance of the zener and the base emmiter volt drops are all imprecise and vary with temperature. Each base emmiter drop subtracts 0.7v from the zener.
Old 4th May 2009, 08:01 AM   #7
Default get this!
ok...from one side of the zener I get +7.6vdc and on the other side I am getting +4.4 vdc.
On the other zener it is the same readings only -, of course .?
Old 4th May 2009, 08:13 AM   #8
Mooly's Avatar
One end of each zener is connected to zero volts (ground). Just read across the diode or from ground to each leg. Is the +/- 5 volts correct at the emmiter of the final transistor (s)
Old 4th May 2009, 08:18 AM   #9
Mooly's Avatar
Check you have 10 volts coming out of those two reg's 7805 and 7905 as this feeds the zeners etc
Old 4th May 2009, 08:22 AM   #10
Default how's this grab ya!
ok...9.5vdc out out reg......4.94vdc off the last emitter....and 3.2 vdc across the zener !....
Need help to indentify zener diode c3v0phHide this!Advertise here!
Zener Diode Question Captn Dave Tubes / Valves 17 11th March 2015 11:28 AM
regulated PS - with Zener diode ErikdeBest Tubes / Valves 13 3rd July 2012 06:36 PM
zener diode question mike49504 Car Audio 2 2nd September 2007 07:17 AM
Quicksilver zener diode mod newears Tubes / Valves 19 31st December 2004 11:41 PM
Zener diode indentification! bbakota2000 Parts 2 23rd March 2004 12:55 AM
