| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 | |
Banned
Anyway, the link above seems to say gnd is needed - it's a pity as I would have liked to isolate the PC completely. I still ask how is the opticics done - it's galvanically isolated, I believe - does anybody know? Last edited by jkeny; 5th September 2009 at 01:19 AM. |
#22 |
*Any DAC with its own power supply* - not my USB-powered DAC
#23 |
USB 2.0 spec section 6.4.2: The GND lead provides a common ground reference between the upstream and downstream ports. The maximum cable length is limited by the voltage drop across the GND lead. Refer to Section 7.2.2 for details. The minimum acceptable wire gauge is calculated assuming the attached device is high power.
According to this article you can also use a chip to isolate usb signals: http://www.analog.com/library/analog..._isolator.html Last edited by glt; 5th September 2009 at 03:31 AM. |
#24 | |
#25 |
What chips are Ayre and Naim using? It seems that they have OptoCouplers working?
::: Squeezebox Touch Toolbox 3.0 and more ::: by soundcheck |
#26 |
Hi.
Here is an interesting article. http://www.edn.com/article/CA6347257.html 12MBit is pretty much the maximum optical USB can do. This is also what TI told me a while ago. There is one solution: ICRON Ranger 442 http://www.icron.com/products/usb/us...er_442_444.php This one is the only device I am aware of which will handle 480MBit/s. It is USB over IP.
#27 |
If you want to isolate galvanically, use a good transformer, with a proper circuit. What makes you think that an opto circuit sounds better? They usually sound worse.
#28 | |
The ADuM parts aren't opto-isolators. They are actually very much like tiny little transformers on a chip. (or they actually *are* little transformers) Also with bidirectional buffers built in to each side of the IC. I think they tend to be faster that opto's... In addition to AD, Silicon Labs (silabs.com) also make some of these style digital isolator. I really think these are the best bet. And since you're isolating the USB stream, they shouldn't crap up the sound any more than uSB already has. -- that is, in the USB path, they should have zero effect on the resulting audio signal - other than that you've now isolated yourself from the computer, which should be a very good thing. |
#29 | |
#30 | |
2. See eclectic2k answer. It will still depend on the jitter tolerance of the receiver chip if the optical transmission and conversion makes things worse. 3. If you run asynchronous (M-Audio Transit) the data/timing quality on the USB link doesn't matter anyhow as long as it stays within the jitter tolerance of the receiver. 4. Ground-loop usually still exists due to shielding if you not go for optical. 5. Through a battery powered receiver (modded Opticis PS ) I can feed BUS powered devices very well -- e.g. my M-Audio Transit is working much better afterwards. 6. I guess you are well aware of the USB-cable discussions at AA, where people spent a couple of hundreds bugs on USB cables to reduce the transmission losses. I don't have that issue at all. Let us know if you found or if you know or if you've tested by yourself a plug'n play device or a DIY solution based on transformers. THX
| PS/Amp isolation in 1 box ? | jimbo1968 | Chip Amps | 5 | 20th May 2005 08:04 PM |
| Mouse Pad Isolation | PeterArsen | Everything Else | 1 | 23rd February 2005 05:07 PM |
| Isolation | eeka chu | Tubes / Valves | 4 | 6th December 2004 07:53 PM |
| isolation pad | rulezzz | Solid State | 0 | 10th January 2004 06:25 PM |
| about isolation | rulezzz | Chip Amps | 1 | 8th January 2004 06:36 PM |
| Page generated in 0.18169 seconds (71.56% PHP - 28.44% MySQL) with 11 queries |
