Need help to make Magic Dac2 work!!
Old 25th April 2009, 07:08 PM   #1
atcgreg is offline atcgreg  Luxembourg
Default Need help to make Magic Dac2 work!!
Hi everyone
i am a newbie in this forum and need your wisdom and help in maybe a simple matter but here what is the problem. I just got the Cambridge MAGICDAC 2 (on EBay) when the power is on there is a lot of hum / noise at the outputs. At first i thought it might be a loose ground connection or something like that but no after checking all ground connections with a multimeter, it is OK. I do not have the schematics to check each stage. When hooked up by the digital input SPDIF to a cd trans the music gets by and it's not distorted.but the hum is louder then the music. Maybe the opamps are dead (ad712) All the LED indicators show that the dac is LOCKED 44.1. etc. I did not try the balanced output cause i do not have the means to do it so I am stuck to RCA cinch output. Does anyone have the schematics or experienced such a thing.
Funny thing I just discovered that also when the power is turned off still the hum is there even when the mains plug is taken out of the wall socket, while still hooked up to the amp. I have changed the amp from Tube to solid state thinking it might be the amp ground loop hum but no again on both amps it is the same hum. turned ON or OFF.
So it's the MagicDac .
Any advice welcomed
Old 5th May 2009, 12:03 PM   #2
Default Caution with RCA socket!!!
Hi
For those that ignored my cry for help in the "hum" issue with Magicdac 2
FYI the cause of the hum/noise was a stupid low cost pcb mounted RCA socket!!!
The previous owner must have used force to plug in the cable because the ground pin was broken. So i just got rid of it and mounted screw on RCA plug. look at the pic.
Thanks to tracing the signal with an oscilloscope found out that on the XLR sockets the signal is ok but on RCA distored with lots of high freq.
Bought it for 20pounds on Ebay.
Now it is back to life
Old 5th May 2009, 12:04 PM   #3
Default the no good socket
this was the trouble maker
Need help to make Magic Dac2 work!!Hide this!Advertise here!
can you make LM3876 work in Class A ? Jonnravn Chip Amps 13 2nd October 2007 04:21 AM
Make an iPod work on Clarion c-bus MrRadi8 Car Audio 3 14th August 2007 10:06 PM
Can't make this address work..... Burnedfingers Tubes / Valves 4 7th July 2006 11:51 AM
Anyone make a VU with a magic eye ? Colt45 Tubes / Valves 6 19th October 2005 09:39 PM
