Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th April 2009, 11:44 AM   #1
Aiace is offline Aiace  Italy
Default Reconstruction filter design criteria.
I'm looking for the criteria to design a good reconstruction filter, but i don't find too much till now. So
1) is it better to make it passive or active ?
2) Can I use inductors to do it or is better to avoid them because the filter could ring?
3) What about phase? I haven't find anybody tha speek about the phase linearity, but my personal opinion is that the phase is important too.
4) where shoud the filter begins to operate ? from 20 Khz or from an higher frequence?
5) Any suggest or scheme?
Thank you Aiace
Old 17th April 2009, 04:22 PM   #2
You need to let us know a bit more about the application.
1. Is the DAC using sigma delta or PCM modulation?
2. Is the DAC doing any over-sampling?
3. Does the DAC provide any limited on-board anti-aliasing already?
4. Is the DAC feeding a transformer coupled output?
Good Luck
Old 18th April 2009, 10:06 AM   #3
I'm using the PCM1794 feeded by an ASRC. I want to experiment sevrale situations from high upsample to bypassing the ASRC. So I think i should better to begin to filters since 20kHz.
The board does not have any anti-aliasing.
No, I'm not using any transformer for now: I 've designed a discrete IV converter that I want to listen at.
Aiace
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 06:28 AM
se, srpp, pcb design criteria Electroshocked Tubes / Valves 13 1st July 2009 09:20 PM
low pass "PI" reconstruction filter ? percy Digital Source 5 6th May 2006 08:45 AM
Drivers selection criteria. beppe61 Multi-Way 8 19th April 2006 05:18 PM
Reconstruction filter from "Opamp applications" (Jung) 00940 Digital Source 7 10th November 2005 10:19 AM
Page generated in 0.07769 seconds (70.64% PHP - 29.36% MySQL) with 10 queries
