Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th April 2010, 07:18 PM   #51
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Yes the analogue circuit is identical even in terms of part labels.
The actual values of the capacitors and resistors are different though, as is necessitated by the 192kHz upsampling vs the 384kHz of the 740C.
What Ianmac has planned doesn't make a whole lot of sense to me though, unless I'm missing something. So the phono stage (with RIAA eq) is to be fed into an analogue low-pass filter with balanced inputs? Is the FM source balanced too?
The analogue stage as it is has no gain to speak of too.
Another thing, the SMD components are small and hard to get to.
What you are proposing is something I personally wouldn't attempt even if I thought it was a good idea.
But in the true spirit of DIY, don't let me put you off!
Glenn
Old 24th April 2010, 09:01 PM   #52
Ianmac is offline Ianmac  Scotland
Apologies If I have not made myself clear
I am looking for the same functionality from my DAcmagic as one gets from cyrus DACXP or a Benchmark Pre.
The ability to process Spdif and Toslink inputs plus two analog inputs from my FM tuner and Phono amp
I need balanced outputs to drive my Hypex mono amps and a gain/attenuation facility to accomodate the differences in level from all input sources.
The analoge inputs will be unbalanced and need to be electronically converted to balanced. Three crosspoints (dual for balanced) will be needed to allow selection of DAC output or tuner or phono. This could possibly go in between the DAC output and balanced output stage.
Looking at the comments on power supply issues it seemed logical to me to address these at the same time thus my looking for a complete diagram so I get a full picture of the Dacmagic.
Like your avatar hope its real 625 pal
Ianmac
Old 24th April 2010, 11:01 PM   #53
Glenn2's Avatar
OK, I don't really see how it can be done with this circuit, at least to good effect, but happy to be proved wrong!
The circuit takes two pairs of balanced signals (there's a dual differential DAC per channel) to produce one. So each pair of balanced signals is processed by a differential op-amp circuit.
DAC L+ & DAC L- ==> DAC L+
DAC L- & DAC L+ ==> DAC L-
DAC R+ & DAC R- ==> DAC R+
DAC R- & DAC R+ ==> DAC R-
I don't see where/how you can bring in your FM/phono signals.
Old 25th April 2010, 08:52 AM   #54
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I'll slap myself over the wrist for going off-topic later, but as there's been a comment about test cards, here's another.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 25th April 2010, 02:04 PM   #55
Glenn2's Avatar
Carole Hersee, then and now:
Old 3rd May 2010, 07:26 PM   #56
I think that it is the best way to output the signal from XLR.
http://www.lynxstudio.com/nav/getFil...&t=productfile
Old 27th May 2010, 02:49 AM   #57
Originally Posted by Glenn2 View Post
Quoting from the first page...
...guess what's in the box on top?
That is a very tidy solution! I like it.
How does the Zapfilter sound with the DM?
Old 8th September 2010, 08:24 PM   #58
Could someone dump for me his dacmagic eprom?
You can't get this part in service because Cambridge don't sell it separately (only complete main PCB) and it is one component which you don't buy in ordinary shop (24lc256 of course, but not programed).
In my dacmagic power supply (stabs on main board) has broke down (probably the reason was voltage surge) and burned few components. I have changed it, but eprom is dead (dacs probably work and receiver too). I don't know if DSP is broken, but without EEPRON I couldn't test it.
This is simple to do and wouldn't take much time. EPROM is easy to remove (socket) and if you want, you can make the programmer by yourself (JDM and serial port in computer). No one of my friends is dacmagic owner and on polish DIY forum I didn't receive any answer. This DIY community is a very famous one, and I hope to find someone to help me. Thank you in advance.
Old 16th October 2010, 05:47 PM   #59
Default Grateful new arrival seeks service manual
Thanks for sharing this information, I just opened my DACMagic to bypass the caps. You helped me to get an immediate improvement and saved me a lot of experimentation.
I couldn't get the service manual from the link given. Does anyone have a copy they can send me, please?
Old 16th October 2010, 07:54 PM   #60
Default The other coupling caps in DACMagic
Has anyone replaced the 10uF NP caps (not the PS filter caps) between the 2 DACs and the filters? I assume this will improve the clarity, but there is limited space so what did you use for this? And is it worth it?
BTW Ian Mac, your postings on VE inspired me to do a lot of beneficial work on a CA 540P and then rebuild a 640P. Thank you very much!
Dacmagic Mods Blue_Max Digital Line Level 50 9th March 2009 09:15 AM
Sony CD-X33ES CD Tray not opening-help? eldarvanyar Digital Source 7 14th January 2008 05:12 PM
Help! Cracks opening in my veneer suzyj Multi-Way 7 28th December 2006 04:42 AM
Cambridge Dacmagic 1 ManUtd Digital Source 1 6th October 2003 10:17 AM
Page generated in 0.11626 seconds (78.43% PHP - 21.57% MySQL) with 11 queries
