Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd July 2012, 10:34 PM   #461
Well, the transformer sums up signals from both opamps, + and - signals. The immediate improvement in the sound is in the bass level and articulation - no more muddiness.
Old 4th July 2012, 05:47 PM   #462
Originally Posted by ClefChef View Post
Removed C17 and C18 from digital inputs 1 and 2 (we absolutely don't need capacitance there)
removed C269 and C264, those are HF filtering caps - snip snip.
Why did you deem it necessary to remove these? Have you thought about what function they perform?
No offense, but it looks more like you've selected a few components randomly which won't stop it working for no reason.
Old 4th July 2012, 06:16 PM   #463
No offence taken...I know exactly what function those caps perform, they should not be there.
Those caps on digital inputs were probably put to filter out HF noise. Problem is that they also add to cable capacitance that would cause an "overshoot" of square digital signal.
Those caps on analog outputs were put to filter out HF noise as well, that is already done by signal processing components up the signal chain.
Old 4th July 2012, 07:09 PM   #464
...my mistake, caps on digital inputs add to cable capacitance and cause signal not to "overshoot" but to become "saw-tooth".
Old 4th July 2012, 09:05 PM   #465
stormsonic's Avatar
Take a look at the picture. They are screwing up the signal.
Old 5th July 2012, 09:08 AM   #466
Interesting - is that the digital input? Do you have the before and afters? They shouldn't really be affecting the signal like that as the -3dB point is way above any SPDIF frequency, and more intended for radio and mobile phone interference suppression.
Old 5th July 2012, 10:57 AM   #467
stormsonic's Avatar
yes, digital input with 100pF cap to ground. And bellow is picture with 100pF cap removed.
Stop thinking in "audio analog signal", flip switch to "RF signal integrity mode"
Old 5th July 2012, 11:55 AM   #468
Where did you have the scope probe? At the input to the mux, and was the mux set to that input?
Old 5th July 2012, 12:12 PM   #469
marce is offline marce  United Kingdom
Digital signal integrity
Old 5th July 2012, 05:24 PM   #470
stormsonic's Avatar
yes, it should be: Digital signal integrity.
But there is clock embedded into signal and must be extrapolated, therefore I intentionally wrote down "RF signal integrity"
Dacmagic Mods Blue_Max Digital Line Level 50 9th March 2009 09:15 AM
Sony CD-X33ES CD Tray not opening-help? eldarvanyar Digital Source 7 14th January 2008 05:12 PM
Help! Cracks opening in my veneer suzyj Multi-Way 7 28th December 2006 04:42 AM
Cambridge Dacmagic 1 ManUtd Digital Source 1 6th October 2003 10:17 AM
Copyright ©1999-2013 diyAudio
